Removing pin 20 was OK ( my error ).
Follow the following, remove these and leave them out, in sequence. Test after removing each chip.
I assume when you said that you remove the buffer, you meant U25 and U26
I remove jumper on J11
U21
U23
U22
U9
U19
U20
U25
U26
U24
These are all the chips that can effect the main bus, in any form. If the front panel starts working stop and let us know which chip was offending things. Most of them are inputs. If it still causes trouble with all of these chips removed ( do keep track of which came from were ) we'll need a picture of the card edge connectors, front and rear.
