Results 1 to 2 of 2
Thread: 5.25" WP light/sensor/notch
    Sep 2006
    South Florida
    1,640
    Default 5.25" WP light/sensor/notch
    I have an opportunity to buy a huge stash of NOS 5.25" DS/DD floppies, cheap, but notchless.
    Short of punching them all, can a simple mod be done to a FDD to basically lock the sensor as always not-WP?
    What would I do? Bridge across the photosensor side?
    If so, I would just put a switch there, like I did my Teac Fd-55GFR for the 300rpm+DS/QD switch....
    FYI, I would use this in my CP/M disk imaging system, not a running system. It would basically be to master floppies from images.
    T
    I would imagine that just bridging the phototransistor would do it, if you want to be super-safe, bridge it with an (about) 220 ohm resistor, in case it's got a funny drive circuit. use a switch by all means, but probably not needed if you're sensible.
    "Don't it always seem to go
    That you don't know what you’ve got ‘til it’s gone" (BANG )
