Page 8 of 8 FirstFirst ... 45678
Results 71 to 74 of 74
Thread: PC/IX Images
  1. #71
    Jun 2009
    Hobart, Tasmania, Australia
    163
    Quote Originally Posted by md95065 View Post
    In fact there were two target platforms for SCO's 8086/88 port of XENIX - one was the PC/XT and the other was a Burroughs machine running BTOS where XENIX actually ran as a task under BTOS (similar to the way in which, today, Linux supports a "user mode" platform aka UML where it runs as a user mode process).
    thanks for highlighting this, I did not know that Xenix could run as a task on CTOS, there is a reference here: https://www.cbronline.com/news/unsys_unveils_btos_ii/
  2. #72
    So, I've got an XT with a compatible controller and a 20Mb hard drive and I gave it a go. I was able to boot it up and start the installation but my hard disk has too many bad tracks in the first couple megabytes. In XENIX, I can just move the partition forwards a bit, but PC/IX only recognizes the first 305 cylinders. Definitely only meant to work with 10Mb hard drives.
    I've got another hard drive on the way - hopefully it will be relatively error-free.
  3. #73
    So.. are these images still somewhere? The link seems to be dead.
    “Thus, we see that one of the obvious origins of human disagreement lies in the use of noises for words.”
  4. #74
    Quote Originally Posted by Jorg View Post
    I'm using the set from WinWorld here: https://winworldpc.com/product/pc-ix/10
