Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 66
Thread: PC/IX Images
    So on a positive note I am proud to be able to say that I've had time to image my second copy of PC/IX in both EMT4WIN and Dave Dunfield IMD imagedisk formats
    Here is the link
    http://maben.homeip.net/static/S100/IBM/PCIX/index.html
    Luckily this activity was performed before my meeting with another disasterous set of Wabash Diskettes . All diskettes were not created equal.
    5,746
    Thanks, I grabbed the goofy ImageDisk #17 that was bad from the first set.
    I regret I haven't installed it yet, but I have a Panasonic Sr. Partner with a 10mb drive not doing anything, so I might do that this week...
    very, very interesting! nice upload. i am going to download these now, and play with it on one of my XT's tonight. i'm assuming there's a very very small selection of software i'll actually be able to run with this... anything like an IRC client? SMTP server? web server?
    i will bust out the ol' 12 inch amber phosphor and put the monochrome card back in for this just for kicks. TTL ftw.
    My emulators!
    5,746
    Quote Originally Posted by Mike Chambers View Post
    Actually, it would be good to test with VGA, because if it works in VGA then that proves it needs an 8088/8086 in order to run (probably uses PUSH CS and POP CS, which are invalid on later cpus).
    As for an SMTP server, web server, and IRC client, I think the answer is a resounding NO because PC/IX was created before those existed! (Well, IRC and web anyway).
    Minix might have functional web/smtp/irc clients and servers though.
    wowowow check out all this software that is designed for minix3
    EDIT: grrr nevermind, minix3 requires at least a 386.
    # ackpack - Minix ACK port
    # antiword-0.35 - a free MS Word document reader
    # apache-1.3.37 - The Apache HTTP Server v1.3.37
    # apr-0.9.12 - apache portable runtime library (gcc format)
    # apr-util-0.9.12 - apache portable runtime utils
    # ascii-3.8 - Interactive ASCII name and synonym chart
    # atk-1.9.0 - The ATK library.
    # audio-1.0.0 - SB16 ISA and ES1371 audio drivers + framework.
    # autoconf-2.59 - Autoconf set of automatic configuration tools
    # autoconf-2.60 - Autoconf set of automatic configuration tools
    # automake-1.9 - gnu automake
    # avra-0.7 - Assembler for Atmel AVR microcontrollers
    # bash-3.0 - GNU bourne-again shell
    # bc-1.06 - Arbitrary-precision calculator
    # bchunk-1.2.0 - CD image format conversion from bin/cue to iso/cdr
    # bcrypt-1.1 - Cross platform file encryption utility
    # binutils-2.16.1 - A collection of GNU binary tools
    # bison-2.1 - Parser generator (requires gnu m4 in m4 package)
    # bitlbee-1.0.3 - An IRC to other chat networks gateway
    # btyacc-3.0 - Backtracking parser generator based on byacc
    # catdoc-0.94.2 - view various file types such as ms word in text
    # cpio-2.5 - a program to manage archives of files
    # CSSC-1.0.1 - SCCS Version Control Software Clone
    # ctags-5.5.4 - build tag file indexes of source code definitions
    # cvs-1.11.21 - Concurrent versioning system
    # dact-0.8.39 - Multi-algorithm compression
    # db-4.4.20 - Berkeley DB - Open source developer database
    # diffstat-1.39 - Produces graph of changes introduced by a diff file
    # diffutils-2.8.1 - GNU diff and friends
    # dungeon-2.7.1 - Text adventure dungeon exploration game
    # ede-1.1 - Equinox Desktop Environment 1.1 (needs EFLTK)
    # efltk-2.0.6 - EFLTK - Extended Fast Light Toolkit 2.0.6
    # emacs-21.4 - The EMACS editor
    # exim-4.66 - Exim - MTA (overwrites aliases, sendmail, mailq)
    # fb - file browser
    # flawfinder-1.26 - Automatically finds security flaws in C programs
    # flex-2.5.4 - Lexical scanner generator
    # flip-1.19 - converts text file between MS-DOS and **IX format
    # fltk-1.1.7 - Fast+lightweight gui toolkit
    # fltk-2.0.0-5220 - Fast+lightweight gui toolkit
    # gawk-3.1.4 - GNU AWK
    # gcc-3.4.3 - GNU Compiler Collection v3.4.3
    # gcc-4.1.1 - GCC 4.1.1, C and C++ compilers
    # gdbm-1.8.3 - GNU dbm, a library of database functions
    # gettext-0.14 - GNU multi-language interface library
    # ghostscript-8.54-gpl - Programs to render PostScript documents.
    # ghostscript-fonts-std-8.11 - fonts for ghostscript
    # glib-1.2.10 - GNU programming utility library (v1)
    # glib-2.10.0 - GNU programming utility library
    # gnu-coreutils-5.2.1 - Port of many basic GNU utilities
    # gnupg-1.4.8 - GnuPG - GNU project's complete and free implementation of OpenPGP.
    # grep-2.5.1a - gnu grep
    # groff-1.19.2 - groff typesetting system
    # gv-3.5.8 - graphical frontend for gs
    # gzip-1.2.4 - gzip file compressor/decompressor
    # gzip-beta-1.3.3 - gzip file compressor/decompressor
    # hexcat-0.0.3 - HEX dumping utility
    # ImageMagick-6.3.1 - ImageMagick - Convert/Edit/Compose Images
    # irssi-0.8.10 - irssi, a nice irc client
    # jikes-1.22 - A Java bytecode compiler.
    # john-1.7.2 - password cracker
    # jpeg-6b - The Independent JPEG Group's JPEG software
    # jwm-1.7 - JWM is a window manager for X11
    # jwm-1.8 - JWM is a window manager for the X11 Window System
    # kermit-2.1.1 - terminal emulator
    # lcrack-20040914 - password cracker
    # less-3.8.5 - A pager like more
    # lesstif-0.93.96 - lesstif - A freeware version of Motif.
    # libiconv-1.9.1 - iconv() implementation - charset conversions
    # libmcrypt-2.5.7 - De-/Encryption library
    # libpng-1.2.8 - libpng is the official PNG reference library.
    # libungif-4.1.3 - this library for working GIF images
    # libxml2-2.6.28 - XML C parser and toolkit
    # links-1.00pre19 - advanced text-based www browser
    # links-2.1pre26 - advanced text-based www browser with X11 mode
    # lpr - port of bsd lpr/lpd.
    # lynx2-8-5 - text-based WWW browser
    # lzo-1.08 - LZO is a portable lossless data compression library
    # lzop-1.01 - fast compression program
    # m4-1.4.3 - preprocessor
    # make-3.80 - GNU make
    # mdf2iso - mdf to iso conversion utility
    # MPlayer-1.0rc1 - MPlayer - The Movie Player
    # mtools-3.9.7 - ms-dos filesystem compatability tools
    # mysql-5.0.41 - MySQL Relational Database 5.0.41 (Client Only)
    # nano-1.3.12 - 'compatible but enhanced' Pico clone
    # nasm-0.98.38 - flexible assembler, support for many output formats
    # nawk - New AWK
    # ncftp-3.1.9 - NcFTP, an nice fullscreen ftp client
    # ncsa_httpd_1.4
    # ncurses-5.5 - new curses library
    # neon-0.25.5 - C library for webdav
    # nethack-3.4.3-2 - Nethack, the famous dungeon exploration game
    # netpbm-10.26.30 - toolkit for manipulation and conversion of images
    # nomarch-1.3 - Unpacks .ARC and .ARK MS-DOS archives
    # nrg2iso-0.2 - Extracts ISO9660 data from Nero ".nrg" files
    # nvi-1.79 - A new vi implementation
    # openssh-4.3p2 - openssh implementation of secure shell
    # openssl-0.9.8a - library of security algorithms and protocols
    # patch-2.5.4 - GNU patch
    # pce-0.1.7 - PCE - An IBM PC Emulator - Boots and runs most DOS applications!
    # pcre-4.5 - perl compatible regular expressions
    # pdksh-5.2.14 - public domain implementation of ksh (korn shell)
    # perl-5.8.7 - perl interpreter
    # php-5.2.1 - PHP Hypertext PreProcessor 5.2.1
    # picasm112c - PIC assembler
    # pine-4.64 - Pine email and news system.
    # pkg-config-0.20 - pkg-config - package configuration management
    # PopTart-0.9.7 - pop client
    # prng-3.0.2 - A library for the generation of pseudorandom numbers.
    # pscan-1.1 - scans C files for common bugs
    # pstotext-1.9 - ps to text converter
    # psutils - postscript manipulation utilities
    # python-1.5.2 - python interpreter
    # python-2.4.3 - python interpreter
    # rcs-5.7 - RCS revision control system utilities
    # readline-5.1 - The GNU Readline Library
    # rman-3.2 - PolyglotMan Reverse compile man pages
    # robodoc-4.0.18 - A source code documentation tool
    # rsync-2.6.7 - powerful incremental remote synchronization
    # screen-4.0.2 - full-screen virtual text window manager
    # sed-3.02 - GNU sed
    # shhmsg-1.4.1 - Library for displaying messages
    # simhv35-2 - a highly portable, multi-system simulator
    # sip-0.4 - Secure Internet Pipe - Create a secure networked pipe
    # slang-1.4.9 - interactive applications library
    # slrn-0.9.8.1 - fullscreen newsreader
    # sqlite-3.3.17 - A self-contained, embeddable SQL database engine
    # src2tex-2.12 - source program files -> TeX format files
    # ssmtp-2.61 - simple smtp client
    # subversion-1.4.0 - subversion version control system
    # tcl8.4.14 - The TCL scripting language.
    # tetex-3.0 - teTeX, a LaTeX distribution
    # tetex-src-3.0
    # texinfo-4.7 - Texinfo - The GNU Documentation System
    # tiff-3.8.2 - LibTIFF - TIFF Library and Utilities
    # tk8.4.14 - The TK Toolkit for use with TCL
    # unrtf-0.19.3 - converter from RTF to other formats
    # unzip-5.52 - for decompressing .zip archives
    # vice-1.19 - Emulates C64, C128, VIC20, PET, PLUS4, CBM-II
    # vice-1.20 - Emulates C64, C128, VIC20, PET, PLUS4, CBM-II
    # vile-9.4 - text editor which is feel-compatible with vi
    # vim-6.3 - vi improved
    # wdiff-0.5 - Compares two files word by word
    # webcpp-0.8.4 - converts source into syntax highlighted HTML
    # wget-1.5.3 - utility to retrieve URLs
    # whichman-2.4 - search for man-pages that match approximately
    # X11R6.8.2 - X Windows R6.8.2
    # Xaw3d-1.5 - 3D athena widget set
    # xv-3.10a - XV 3.10a - graphics viewer
    # zip-2.31 - make .zip archives (compressed files into one)
    # zlib-1.2.3 - zlib compression library
    # zsh-4.2.6 - The Z shell
    yes, i am drooling too and this time it's not from a hangover!
    My emulators!
    what we really need for XTs is a full pentium 4 emulator. THEN we could run Vista on it, and use a hard drive as virtual memory since the XT's RAM is limited.
    My emulators!
    Yeah, but just think mow many 360KB floppies you'd need to install it. Unless you plan on getting a DVD drive to run in an XT, too
    Then again, you could always do a network install, if Vista supports it...
    Sep 2006
    South Florida
    1,640
    Quote Originally Posted by amouse View Post
    Here is the link
    Did you try the baking-in-the-oven trick on those floppies?
    I don;t think it's just Wabash - I have had to throw out all kinds of disks, because you could almost SEE the oxide coming off the media! Maxell, memorex, elephant, Sony, the list goes on and on...
    T
    Yes whilst I did use Minix from an early age and was often to be seen clutching Andrew Tanenbaum's famous Modern Operating Systems, I would say though that PC/IX was really in a different league.
    It was full on UNIX, you know compilers, SCCS, accounting, the works. All running on an 8088. Again, doesn't anybody have the documentation to this or VM/IX? If we could have this scanned and published I think you would agree what an amazing product for the time it really was.
    Regards marcus.
    I was involved with PC/IX since its inception and I have a complete set of PC/IX manuals, 'Second Edition', in pristine condition:
    o System Manager's Guide
    o Programmer's Guide
    o Text Processing Guide
    o User's Manual (aka 'The Fat Book')
    Interested?
    Chris.
    p.s. As this forum thread appears inactive, I'll leave an email address so that I don't have to keep checking: cas194@gmail.com
    Last edited by cas194; February 19th, 2010 at 02:29 AM. Reason: Inactive? Left e-mail address
    Sorry to dig up an old thread but I'd love to try this on my 5150 and my 10 MHz clone. It seems the links are down however, perhaps someone could point me to an updated link?
