Results 1 to 4 of 4
Thread: problems with streaming audio and a router
    Default problems with streaming audio and a router
    my friend wants to listen to the live streaming audio of the Man U vs. Arsenal game this Sunday, and he has to keep disconneting his router in order for it to play properly
    he keeps getting a "can't connect to proxy server or can't detect server" error
    can anyone help me with him? i know jack about routers and proxy servers. is this some kind of firewall problem he is having?
    The vic rocks!
    here is the exact message:
    THIS IS THE EXACT ERROR MESSAGE WHEN I TRY AND ACCESS A REAL PLAYER STREAMING AUDIO LINK
    "UNABLE TO LOCATE PROXY SERVER..THIS PROXY SERVER DOES NOT HAVE A DNS ENTRY
    PLEASE CHECK THE PROXY SERVER NAME AND TRY AGAIN"
    The vic rocks!
    Its probably a firewall issue. He might not even have to connect via a proxy server, if so he could just connect directly to the net
    He could also see if the link works/url is correct. Or see if there's another source of the broadcast.
    thanks.
    i am just forwarding any replies to him, so this is good
    The vic rocks!
