Thread: AT&T UNIX PC - Need to hack user/password for access
    Default AT&T UNIX PC - Need to hack user/password for access
    Hi
    One of my students was able to repair an AT&T 7300 (67MB version) UNIX PC powersupply. Now it boots up, but we don't have the username and password. Any suggestions?
    -Bill
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    5,603
    1. Take the hard drive out
    2. Put it in another computer that can read it
    3. Use a utility to scan the entire disk for "root:" until you find a standard /etc/passwd entry
    4. Edit the data you find to take out the encrypted password between the first two colons, so that "root:fd78xuifdsjl:0:0:" etc. turns into "root::0:0:" etc.
    5. Put it back in and root will no longer have a password
    Finding a machine to read the disk might be tough, although if it's just MFM you could get lucky and connect it to a 1980's PC with an MFM controller and use Norton Diskedit to do the scanning and editing.
    Another option is to just simply record what the password is (it's a 13-character encrypted string) and then use John The Ripper to crack the password on a very fast modern machine (brute-forcing it should only take two weeks or so).
    I got a lot of replies to this ... the answer was to use the "install" user and hope that the original password was not changed (no password/blank). It worked, and root access was granted.
    Thanks
    bd
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Type in Tutor, Then once your in the system you can figure it out.
    I have (4) at&t unix pcs & two sets of books w/software to play with...
    Proving once again that to maintain security, it helps to restrict physical access. Yes, I know, if it is on the internet, what's the diff....
