Thread: Joystick on the Apple IIe?
    Default Joystick on the Apple IIe?
    Well, I came across a joystick for my IIe, but after plugging it in and selecting the joystick option in Spyhunter, I found it completely unresponsive . Does the IIe also require some sort of card to run this hardware ? Any tips are appreciated !
    post a picture of how you have it attached. The Apple II connector for a joy stick is internal, on the motherboard. Do you have a serial card substituting for this default, and if so, did you load whatever program you'd need to load to bypass the default?
    Bill
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Sep 2008
    Columbia, SC USA area
    589
    1st, try it in another game, If you want I'll post a joystick test program. 2nd, try another joystick to see if the port is working. You only need the built in paddle port on the IIe, no cards required.
    Cheers!
    Wmmullaney
    Collection: Replica I TE, 3 Apple IIe, Apple IIgs, Apple Performa 630cd 68k, 4 PowerPC Performa, 2 Timex/Sinclair 1000 and 1500, PC/AT c286 clone, Commodore 64 and 128, NCR box with a 386 mobo, TRS-80 PC-2, DreamCast, PlayStation 1 and 2, 2 iMac G4, Powermac G3 beige and aqua, Twinhead 386, Toshiba T1910, Zenith zwl-183, set of Intel MCS-8 boards (CPU, RAM, ROM, I/O)
    All right, so I tried it again after adjusting some centering knobs on the side. It's a Gravis Mark VI Analog control, and it's the only one I have for the Apple, so I can't test any others to see if it's the joystick that's the problem. After trying some other games, I found out the directional stick works, but the buttons, the one on the stick and two on the side, are not working, or at least don't seem to be. However, I don't know why the stick would work and the buttons wouldn't. There are seemingly adjustment knobs for the buttons, do they need to be set a certain way?
    Sep 2008
    589
    Open the stick up and clean the button mechanisms.
    Cheers!
    Wmmullaney
