Results 11 to 20 of 31
Thread: IBM PC AT 5170 BIOS versions
    Nov 2008
    Portsmouth RI
    372
    What's the difference between a type 20 and type 22. I got a st-4038 that someone wrote type 22 but all the docs say type 20?
    Thanks,
    framer
    6,329
    Quote Originally Posted by framer View Post
    ANSWER RE IBM 5170 BIOS: See [here].
    ANSWER RE OTHER BIOS': Varies from BIOS to BIOS. Levels of IBM compatibility vary. Some clones may have been using 20 and 22 before IBM did.
    Dec 2007
    Texas Hill Country
    116
    Is it absolutely pertinent that 150ns or faster EPROMS be used? Would I be causing problems if I used 200ns (which is pretty much all I've got)?
    Also, someone asked the question without posting a link - is it a problem using the most recent BIOS in a type 1 6mhz planar?
    6,329
    Quote Originally Posted by pkhoury View Post
    IBM are the ones who indicated 150 ns (quote: "ROM is not parity-checked. Its access time is 150 nanoseconds ...").
    You could try 200 ns, and if lock-ups are experienced from time to time, then either your EPROMs are bad, or 200 ns is not fast enough.
    An answer is [here].
    Dec 2007
    Texas Hill Country
    116
    Thanks. I found one chip that's 150ns. Hopefully I'll find a second to complete the pair.
    As for the 601 error upon boot, I'm presuming press F1 and the system operates normally? I believe it presently has an AMI or Award BIOS in there now, but I want to revert back to the IBM BIOS so I can install OS/2 1.x.
    It's a shame it's not able to modify the newer BIOS images to not give the 601 error; I'm going to assume part of that is due to the new Type 20 HDD added to the drive table?
    6,329
    I do not remember.
    I think the behaviour is either:
    1. Done on purpose; or
    2. A bug introduced when the BIOS authors modified the floppy portion to cater for 720K drives and diskettes; or
    3. A bug introduced when the BIOS authors modified the floppy portion to improve the BIOS.
    With enough effort (investigation + fix), either can be removed. If the behaviour was done on purpose, it may not be wise to remove it. Again, it all 'boils down to' the results of an investigation.
    Hey Everyone,
    Sorry if this is mildly off-topic, but I have a few 5170's I'm working on and I hit a really weird issue. I am trying to use a 128mb DOM IDE module on a 16-bit IDE card with the AMI Bios in a 5170. I was able to make the chips, and it's coming up fine. The module I'm using has a geometry of 492 Cylinders, 16 heads and 32 sectors which is well below the 504mb limit. The machine comes up with this setting, sees the HD, lets me FDISK and format and then, nothing! After playing around some more, I booted from a floppy and go right to the C drive no issue. It will let me create a directory, and copy files from the floppy. I then just tried to run command.com from the root, and then I get a read error. I then noticed, I cannot seem to read anything from the drive no matter what I do! I thought perhaps it was just responding too quickly, and the only other drive I have sitting around is an older 200gb IDE. I set it to 1024-16-63 which is the 504 limit, and I get the exact same behavior. Maybe this drive is too fast too?
    Whatever the case, I'm really perplexed on what else to try short of getting an older HD. I was hoping this setup would work.
    Has anyone seen this, or any suggestions?
    Thanks!
    -Kevin
    I've got motherboard of original IBM PC 5170 motherboard (01/10/84) and dumped it by DUMPAT.EXE.
    Then I splited dumped BIOS by using WinHex.
    Now. original BIOS of IBM PC 5170 (01/10/84) is verified perfectly.
    I see all the information says 27256 eproms with 150ns are needed to burn the bios roms. Sources of those chips are a bit sparse. I was looking at the cmos variants "27C256" and wondered if they were compatible such as: https://www.mouser.com/ProductDetail...SI%2fRUlfO5T04.
    I found the answer http://www.minuszerodegrees.net/bios/bios.htm. "ROMs can be created by programming 27256 EPROMs or 27C256 EPROMs, ones rated at 150 ns (or faster)." The 27C256 I linked above are compatible. Now to learn how to use this old GTEK 7228 programmer
