Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: IBM PC AT 5170 BIOS versions
  1. #21
    I've got junk of IBM PC 5170 type 1 motherboard.
    This is very early Type 1 release of IBM PC 5170 BIOS.
    Part No. : 6181024 (16KB) + 6181025 (16KB) = 6181028 (32KB) , 6181026 (16KB) + 6181027 (16KB) = 6181029 (32KB)
    https://mega.nz/#!ngtklAZB!cUw4fTZlJ...ZZp8tnSY9MH9mM
  2. #22
    Jan 2014
    552
    Wow! Can we see the entire board please??
    Bobby.
  3. #23
    6,117
    Quote Originally Posted by fs5500 View Post
    Good to see these chips, listed in figure 9 of the document at [here], eventually 'surface'.
    Because of the 16 KB sized ROM's, we expect shunt block U131 to be in the '27128' position (per [here]).
    Also expected, are Intel made 8259A interrupt controller chips.
    Now that we have a photo of the ROM's, I will later add details to [here].
  4. #24
    @bobba84
    Sure, here it is.
    @modem7
    Thanks very much.
  5. #25
    Jan 2014
    552
    Thank you!
    Bobby.
  6. #26
    Silly question - could the unpopulated 16 bit connector positions be populated to give the AT 8 16 bit slots instead of just six?
    tnx.
    g.
    Proud owner of 80-0007
    http://www.f15sim.com - The only one of its kind.
  7. #27
    Quote Originally Posted by geneb View Post
    You could do that. But it means you cannot use 8-bits cards any more that only fit in a 8-bits slot like the original IBM CGA video card.
    www.baltissen.org
  8. #28
    @gene . @Ruud
    I recommend to discuss about non related BIOS topic on another thread.
