Thread: Keyboard
    Default Keyboard
    Hey guys, looking to attach a keyboard to my commodore C386SX-LT. I have one COM port on it and one printer port. My question is, is there any way to get a keyboard to attach to either of these ports? If the Com port, I also need a way to split it to mouse.
    Thanks
    No clue why I put this in software lol
    Mod's please move
    Dec 2005
    Toronto ON Canada
    7,094
    Don't know about your particular setup, but with normal DOS and Windows systems you could plug in a serial keyboard and use either a wedge to redirect it to the keyboard or the WIN tools to do the same. Trouble is, the mouse would use the same port...
    I have a built-in modem I am removing and replacing with another COM port. I just didn't know there was such a thing as a serial keyboard. Please enlighten me.
    30,697
    DOS does give you a certain limited functionality with the CTTY command. Basically, you can do CTTY COM1: and DOS will read from the comm port for input.
    But there are gotchas.
    The first one is that it's only good with programs that use DOS functions (e.g. 1, 6 and 10) for input. Programs using the BIOS calls won't work--and there are a lot of those.
    The second is that no scan codes are returned and you don't get cursor or function key control. DOS expects a dumb ASCII TTY-type input.
    But if you really want to take a PC keyboard and have it output ASCII codes over a serial link, I'm sure that I've seen a PIC project to do just that.
    You could also write your own TSR/driver to simulate a PC keyboard from ASCII input and patch the INT 16H vector to your BIOS.
    Just tossing some ideas out....
