Results 1 to 10 of 14
Thread: Scsi cd-rom in dos
    Lightbulb Scsi cd-rom in dos
    I have the following SCSI CDROM
    Teac CD-532S
    Anyone know where or have a Dos Driver for this particular Drive.
    Thanks!
    30,694
    Will an ASPI driver + Adaptec ASPICD.SYS do the trick? It does for all of my SCSI CD-ROM drives.
    In other words, if you have a Trantor T160, you'd do something like this:
    In CONFIG.SYS:
    DEVICE=MA160.SYS
    DEVICE=ASPICD.SYS /D:MSCD0000
    In AUTOEXEC.BAT:
    MSCDEX /D:MSCD0000
    Talking Teac scsi cd-rom
    In CONFIG.SYS:
    DEVICE=MA160.SYS
    In AUTOEXEC.BAT:
    MSCDEX /D:MSCD0000
    I will give it a try.. See how it goes.....
    The SCSI adapter card is more the issue. The drive itself should not matter.
    IBM 5170/5053, 2 x 5150/5051
    Sun IPC, Ultra1 and SPARCclassic with tape, disk and CD
    HP Apollo 9000/735
    Silicon Graphics Indy, O2
    Radio Shack TRS-80 model 100
    Apple Mac Plus, DEC 5000/25
    Quote Originally Posted by paul View Post
    No arguments there..
    The card i have is a TMC-840, at boot up, the cd-rom is identified correctly, so just a matter of getting the proper software and it should work.
    Anyone have the proper software?
    Google is your friend. Search for Future Domain drivers.
    I perfer not to recreate the wheel if someone has a spare!
    I am working on it...
    30,694
    See attached file: Use the MCAM950.SYS driver (it works for the TMC-850, so it might work for your 840) and the FDCD.SYS driver (check the .txt files for more info).
    Good luck--I hope that your old card will work with this stuff!
    FD PowerSCSI
    (I'll leave the file up for a day)
    (P.S. While I've got it in front of me, does anyone need the Trantor SCSIWorks images?)
    Smile
    FD PowerSCSI
    Well I got everything working, I downloaded your zip, never know when I might get that type of SCSI CARD.
