Page 1 of 22 1234511 ... LastLast
Results 1 to 10 of 217
Thread: True CGA vs VGA card in CGA mode
    Default True CGA vs VGA card in CGA mode
    Hi all
    Is there any performance differences between a true CGA card and a 8-bit VGA card running CGA graphics ?
    If it has switches so it oculd be toggeled to CGA mode on startup, it would operate as a CGA, and there would be no differences unless the card is of lower quality and price.
    However, if it's configured as VGA on startup, it might have some problems with certain CGA graphics modes.
    Apr 2005
    Stevens Point, Wisconsin
    2,315
    Default memory map
    Well, they typically live at different addresses in the pc's address space.
    0A0000-0AFFFF VGA/EGA Video Memory
    0B0000-0B0FFF Monochrome Video Memory
    0B8000-0BFFFF CGA
    patscc
    Quote Originally Posted by patscc View Post
    0B8000-0BFFFF CGA
    patscc
    Okay. I was thinking more along the line: If I run a game in CGA on a VGA card or run it on a true CGA card, will there be any noticeable performance differences ?
    I talk simple games, like Alley Cat
    Quote Originally Posted by QuantumII View Post
    I have had some problems with that. Often, the VGA is toggeled into wrong video modes, ant it doesn't really support some of the special modes of the CGA, like some of the CGA's graphics mode, like morecolors and the BG/red/cyan/white palette.
    See the attachement of running Flightsimulator 2.13 (Booter) on a VGA in VGA mode and VGA in CGA mode. Note that "Signal Error" alert in the upper right courner on one of the pictures, hence, NOT recomended on CRT monitors.
    Galaxian is one game I know that does this. It works on some VGA monitors, but on others the picture loses sync.
    Moon Patrol always locks up about 7 seconds into the game (Demonlord noted this on his site). Both of these games have some kind of problem with VGA, but I'm not sure what.
    VGA is BIOS compatible with CGA, but not register compatible. At least 60% of CGA software works on VGA, but the other 30% either partially or completely fails. This can be caused by any of the following:
    *Setting video modes or color palettes by writing directly to the registers
    *Using the 160x100 pseudographics mode
    *Raster interrupts
    *Tweaking the 6845 registers to produce effects like screen shaking
    Yeah, I tried FS on VGA, and it was just like your picture.. Say, did you boot the game from a floppy or did you run the fs.com file ?
    I booted from a floppy (from retrogade, that one got no hidden message on it).
    You say you got a CGA with a RCA jack. If you got a monitor/TV capable of displaying NTSC, you could connect it to the CGA. FS is a lot better in composite than RGBI.
    29,591
    How about a CGA with a scan converter box (as discussed on other threads?). I assume the idea is to use a VGA monitor.
    Yes, if I cannot get a CGA monitor within reasonable time (I'm an impatient guy sometimes) I'll get one of those.. They could be nice to have anyway
    Current machines:
    PCs: IBM PC XT 640K, IBM PC XT 256K ,IBM PC XT , 2x IBM PC AT, Compaq Portable I, Compaq Portable II, Compaq Portable I/286, Philips Logic Analyzer XT clone, IBM PS/2 Model 30 286 , HP 95X, HP200LX (2x),Compaq SLT/286.
    Apple: Macintosh 512k, Macintosh SE, Macintosh Classic, PowerBook 170, iBook Clamshell, iBook G3,iMac G4 , TiBook's, Apple IIc, Many newer machines (G4, G5, Intel..), 20th Anniversary Mac
    Others: Commodore 64C,Amiga A500, CCS S-100 System, SNES,
    Wanted: Macintosh 128k, Hard Disk 20, System disks and games for the Mac
