Results 1 to 4 of 4
Thread: Power up problem on a Cray EL98
    Default Power up problem on a Cray EL98
    Greetings all,
    A friend and I recently acquired a Cray EL98. On power up we are receiving a Memory PS error. The memory voltage at the test point is 5.4VDC, but since we have no documentation on the EL we don't have a clue if this is a good thing or not. So if there are any EL98 Techs out there, or someone who has a copy of "Cray Y-MP EL Computer System Hardware Troubleshooting and Maintenance Manual (CMM-0431-0A0)" we would really appreciate any assistance with this problem.
    Thanks,
  2. Default
    Try calling Cray. They might give you some help on what to do. They'd probably be delighted to hear from you.
    How old is it ?
    Apr 2005
    Stevens Point, Wisconsin
    2,315
    Oohh, a supercomputer just the right size to hug.
    I want one. Until some one gives me one, I guess I'm sol.
    What's it running, UNICOS ?
    Have you looked at CrayDoc ?
    The 5.4 sounds spot-on, but might be off on what I think the memory technology is. Possibly a secondary supply line ?
    How many mem boards are in the beast ?
    Have you tried posting to
    comp.unix.cray
    where the hard-core Cray junkies hang out.
    patscc
    Well we received a new power supply from a kind sole. The EL boots to System Ready. Unfortunately, we not appear to have a faulty IOS Winchester drive. We have successfully imaged off the contents of the drive and are now searching for a Seagate ST1239N hard drive. Slow but steady progress is being made.
    Cheers
