Thread: Help identify soundcard
    Default Help identify soundcard
    Can anyone help me identify the following soundcard.
    http://images.tradera.com/778/75914778_1.jpg
    It seems like a 16-bit isa that only use the 8-bit isa card.
    Could the daughtercard be memory or wavetable extension?
    JT
    Apr 2005
    Stevens Point, Wisconsin
    2,315
    Default Fcc id
    Is there a FCC ID on it ?
    patscc
    Quote Originally Posted by JT64 View Post
    JT
    Oh it is not mine just looking for objects on the net patscc
    JT
    Sep 2003
    Ohio/USA
    7,375
    Probably a wavetable add-on. Would have to see the other side to know for sure if it is realy an 8 bit card, probably not.
    Looks like a common Crystal chip set, probably an FM type sound card. Yes, the add on card is probably a Wavetable upgrade (i.e. upgrades the common FM card to a wave table type card). If you don't see any company names on the card, it's probably a generic knock off of something common - probably Sound Blaster compatible. You might check Crystal Semiconductor's web site. They may have generic information and drivers for the chip set that may tell you more.
