Results 1 to 10 of 27
Thread: Browser for Windows 3.11
    Default Browser for Windows 3.11
    OK, what's the "best" browser for WFW 3.11? I tried IE 5.01 and NS 4.07. I don't think I found a single site that rendered properly.
    Any opinions?
    Kelly
    I really haven't tried to get my 486 in net yet, but have you tried early versions of Mozilla?
    4.08 was the end of the line for Win3.1. Guess you could try 4.08 instead of 4.07. Unlikely much will improve.
    ftp://ftp.netscape.com/pub/communica...ne/n16d408.exe
    Jul 2003
    Västerås, Sweden
    6,277
    There is also Opera 3.62, but someone wrote it is horrible on Windows 3.11. YMMV, it may be worth checking out.
    http://arc.opera.com/pub/opera/win/362/english/
    Elsewhere the OffByOne web browser was mentioned, but it seems not available in a 16 bit version?
    http://offbyone.com/offbyone/
    Anyway, doesn't Windows for Workgroups run 32-bit code as well? I seem to remember it is different than the regular Windows 3.1 in this matter, or perhaps I've been dreaming. Would installing Win32s allow any newer browser (i.e. Firefoxes) to run?
    Anders Carlsson
    That's true. You could install win32s addon and try later 32 bit version of Netscape.
    I checked the list of compatible software for win32s. It didn't list netscape but I'll try it. IE 5.5 is listed as not working.
    I do have win32s installed. Gotta have my freecell.
    Sep 2003
    Ohio/USA
    7,682
    IE 5 works ok if the cpu can handle the load under Win 3.1 (I tried it on a 386 and it was too slow).
    Netscape tends to just blow up when in use for some reason.
    Years ago I used to use "Arachne" under dos, a few boxes to fill in, so not totally plug & play but it was good & it should work with 3.11, There was also the "Mosaic" browser, but I never got to use that. (perhaps I should have!).
    "Don't it always seem to go
    That you don't know what you’ve got ‘til it’s gone" (BANG )
    Jul 2003
    Västerås, Sweden
    6,277
    I think the problem is that many web sites today have a CSS driven layout, DOM and JS, even Flash which certainly is a big problem on 16-bit Windows if the Flash Player is too outdated. What you would want is a modern browser which can handle all the CSS and other stuff, but compiled to run on Windows 3.x. Even with browsers you can compile yourself, I suppose it isn't quite that easy to get a working 16-bit binary.
    Anders Carlsson
    carlsson nailed it. Its the java and flash thats the killer. Flash you can do without, any website that relies on it isn't worth going to anyway, but you're going to need at least CSS and java for a "normal" experience. The older browsers like Netscape 1.0, Cello, etc. won't do it.
    nige the hippy's suggestion of Arachne is perhaps not so bad. I see it it still out there and has a following. I regularly use a minimal browser called DILLO. It only does text and pictures, but it also doesn't choke on anything. Apparently there is a version for Windows but it is said to be somewhat unstable. It still might be worth a try.
