Results 1 to 9 of 9
Thread: Upgrading from a 486SL to a 486DX/DX4
    Mar 2009
    DE, USA..
    2,750
    Default Upgrading from a 486SL to a 486DX/DX4
    I've on the way a Compaq LTE with a 486SL at 33mhz. While this is probably sufficient, I'd like to upgrade it with an IBM 486DX4 I have sitting around when it gets here. I realize that the 486SL runs on 3.3v and an ordinary 486 on 5v, but would this be a problem? Would the 486DX4 run on 3.3v? Would the bus of the laptop be capable of 5v? Am I crazy? :P
    30,641
    Isn't the 486SL a soldered-in QFP? The DX4 is a PGA package. How are you going to do this?
    Forgive me if I show my ignorance.
    All of the 486SLs I have known are PQFP, so I think you've hit it right...
    Mar 2009
    DE, USA..
    2,750
    I didn't know.. Since my 486SX/DX laptops are all simple PGA I had assumed the SL would be as well. That's a shame.
    It should be PQFP, but that doesn't make it an impossible upgrade. On 386SX motherboards I've successfully sliced off the chips using a utility knife, removed all of the old legs with an SMT soldering iron, and replaced the chip with a TI486SXL. The pin spacing on the 486SL should be the same as the 386SX, so I would say this procedure is doable. Naturally you'd have to be pretty confident in your soldering skills.
    I'm planning to upgrade my TP750 with 486SL with an am5x86-133. There used to be businesses that did this.
    V'Ger XT
    30,641
    Quote Originally Posted by Anonymous Coward View Post
    That--and how are you going to go from a SL to a DX4?
    More to the point, why? Why not just pick up a cheap used P1 if performance is important?
    Yes, it would only be for the internal clock multiplying - the 486SL has a math coprocessor on board. Really all it was is a low-power 486DX in PQFP design. It would be more interesting to me to replace a 386SX with a 486SLC2, or a PQFP 386DX with a 486SLC3.
    Mar 2009
    DE, USA..
    2,750
    The only point was to go from 33 to 100mhz.. I honestly don't need the power, I just love the i486 and would love to get a portable one that pushes the platform to it's limits. Pentiums are boring, heh. The box I'm getting runs Win95 as well, and if I had been able to get to 100mhz it would've performed a tad better.
    I'll likely just stick plain DOS and maybe a Win3.x copy (just for a few progs/games) on the thing..
    Jul 2005
    United States
    2,241
    Quote Originally Posted by Raven
    Ever thought about seeking out a laptop with a 486? Like one of the common Toshiba/IBM ones or the uncommon Compaq Portable 486?
