Page 48 of 97 FirstFirst ... 3844454647484950515258 ... LastLast
Results 471 to 480 of 962
Thread: Powertran Cortex
  1. #471
    The only scan I have for the TMX9909 was taken from the TMS9900 Data Design Book, Jim. That would have been an abbreviated version of the regular document.
    @Dave, many thanks for being willing to pass on the Marinchip once you're done with it. I've waited for one of those forever, so knowing that an end is in sight to my quest is very refreshing!
  2. #472
    Aug 2011
    Near Hindhead, Hampshire. UK
    162
    Quote Originally Posted by Ksarul View Post
    Maybe that's what I have, I just didn't want Stuart spending time scanning it if we already had it, I must remember to check tonight.
    I would like to buy one of your Parallel port/joystick board pcb's if you have one spare.
    Jim
  3. #473
    As soon as I've made sure I didn't miss anything in the layout I did, I'll send off to get a few made--and I'll make sure one is reserved for you, Jim.
    I had to go back and check my PDF files too, because I wasn't sure on the TMX9909 datasheet either--you just beat me into making the initial observation that we had something already.
  4. #474
    Jul 2009
    Southampton, UK
    169
    Quote Originally Posted by Jim Hearne View Post
    Jim
    B*gger - there's actually a copy on Dave H's Powertran Cortex.com site. Didn't realise we had this. I've scanned and PDF'd the copy I borrowed anyway, and it has some handwritten notes for the PP95 on one of the pages which might or might not be useful somewhen.
    Stuart.
  5. #475
    Aug 2011
    162
    http://bitsavers.informatik.uni-stut...9909_Dec82.pdf
    Is this the same as you have Stuart ?
    Jim
    Sorry, posted before I saw your reply.
  6. #476
    Jul 2009
    Southampton, UK
    169
    Jim
    Yep, the same.
    Stuart.
  7. #477
    Jul 2009
    Southampton, UK
    169
    MPE Stuff - Disk Catalogue.zip
    Next installment attached - catalogue of the 5.25" and 8" disks. It's in a zipped Word doc - hope people can open it OK. With the 5.25" disks, I've tried to group them into categories, then have sorted the list by category and disk label title. The 8" disks are already sorted into some sort of order so I've just done a straight list of them.
    Dave H - with your knowledge of MDEX and such, do you know what, if any, of the stuff on 5.25" disk can be used with a plain Cortex with floppies? (There is a disk of Cortex games I notice!) Or does it look like pretty much of it is for the PP95 system with the extra RAM and the Winchester drive?
    Stuart.
  8. #478
    Jun 2009
    South Florida, USA
    132
    Quote Originally Posted by Stuart View Post
    Stuart.
    MDEX runs on a standard Cortex. No extended memory or mods required. The disk images on my website are the complete suite of everything that was given to the User Group when MPE no longer wanted to be involved. More than happy to provide guidance for anyone who wants to try it. There are several programming languages (compilers) and I did a "Hello World" in all of them.
    The most challenging aspect was using the Cortex's 40 column display because MDEX was designed to run with a 80x24 terminal. That was my main drive to add the Maplin V9938 card, because the 80x24 mode alone made it a 'proper computer'. Even under Basic/CDOS the 80 col mode made things a lot more user-friendly.
    That's a lot of disks...... Yikes!
    Dave.
  9. #479
    Aug 2011
    162
    You must have been up all night typing that lot in Stuart.
    Jim
  10. #480
    Aug 2011
    162
    Ok, so what is NOS, all I can find on the net is that is "Network Operating System" but that seems rather later than the cortex.
    Thanks,
    Jim
