Page 6 of 95 FirstFirst ... 23456789101656 ... LastLast
Results 51 to 60 of 948
Thread: Powertran Cortex
  1. #51
    Maybe processing the listing will give you a machine readable copy of the source code. As a matter of interest how did you come by the listing?
  2. #52
    Jun 2009
    South Florida, USA
    130
    Yeah I guess the next step would be to try and put it through OCR to try and extract the text.
    In 1994/5 I had built a SCSI interface for the Cortex and had more or less finished what I called HDOS. For the life of me I can't remember what for but I needed some info so I went through all the User Group letters I had (which was extinct by about 6 years plus!) and I tried contacting some of the people involved. I ended up meeting with one of the guys who had run the Group and he said if I gave him the hard drive/SCSI design and driver code, I could have everything he still had. One of those things was the listing! I don't know how the User Group got it though. I also got some extra manuals for the MDEX O/S plus a couple of other compilers & tools for MDEX. There was a lot of passing stuff along as each of the bigger companies involved no longer wanted to support the machine any longer. I always hung on to everything I got as I wanted to get back into it 'one day'...
  3. #53
    I do have a bunch of the 74LS612 Memory Mappers, so that chip isn't a problem either--the problem was with the pinout of the 74LS2001, since that is the one chip I don't have sufficient info on. Many thanks for the extract of the bus arbiter logic.
    Seeing all of the information that is actually out there for these has me in a major state of anticipation to read all of it! I plan to put direct scans of all of the ETI articles I have original copies of into the Cortex folder on WHTech this weekend, including a single high res scan of the component side of the board instead of in halves like the other copies I've seen.
    One interesting question, the component mask numbering on mine bears absolutely no resemblance to any version described so far--almost everything is different. . .but the component positioning is the same. Any idea how that one came to be, and are there schematics that reflect this other number scheme (note it isn't the minor changes noted in either the ETI articles or the Powertran construction manual that reprinted them with some corrections)?
    Once again, many thanks!
  4. #54
    tms9995 - was the info in my PM of use?
  5. #55
    Jun 2009
    South Florida, USA
    130
    I didn't know I had a PM. I'll check it out - thanks
  6. #56
    Jun 2009
    South Florida, USA
    130
    Quote Originally Posted by Ksarul View Post
    If you get the 31 page download from old-computers.com, there is an article called "Parallel I/O for the Cortex" (page Cortex_20.jpg). That shows the plug-in header for the 74LS2001. It enables the E-Bus hardware on the Cortex PCB to work.
    As far as the component numbering, I believe I recall that when the kits came out, there was kind of a Rev B to the PCB artwork and hence it differed from the original ETI articles.
    I have finished scanning the bulk of my documentation and have PM'd Ksarul for his help in getting it up on the FTP site. The Emulator is good enough for sharing too.
  7. #57
    I just finished a major documentation upload to WHTech at:
    ftp://ftp.whtech.com/Powertran%20Cortex/
    Many thanks to TMS9995 for scanning all of this stuff in and making it available to the rest of us.
  8. #58
    Jun 2009
    South Florida, USA
    130
    Wow, the cover of the first ETI brings back some memories. I was in the computer room at school and my friend came in (he was an ETI subscriber, whereas I had the sister publication Hobby Electronics) and he said, "This is it!" and threw down the magazine in front of me. After he explained all it's attributes, I was sold. Three of us ended up with one. My second machine is the one I bought from my friend when he went off to university.
  9. #59
    Jun 2009
    South Florida, USA
    130
    Default 74ls2001
    I think what is interesting is that if you zoom in on the picture of the ETI cover, there appears to be a chip fitted in the location of the 74LS2001! Despite what Tony said and from my experience that it never existed, something obviously did!
  10. #60
    I've got the complete internal logic for the 74LS2001--just not a bullet-proof identification of which pin each of those signals need to reside on. Some of it isn't used on the Cortex, which is why I was hoping someone had the signal listing for what belonged on which pin on the chip. With the signal name to actually designated pin position, I can design and program a true replacement for it. . .and then it will be around again. As a side note, there appear to be about 300 of them somewhere in Poland, assuming that they really are the same IC. . .I haven't gotten a response yet from the company that says they have them though, so they may be vaporware.
    I'm glad you liked the inclusion of the cover. I have the Aug 1984 issue as well, I just need to finish the scans for it. It contains the rest of the Jun 1984 article along with the board layout for the parallel board.
