Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: I need config.sys and autoexec help!
    Default I need config.sys and autoexec help!
    Unfortunately growing up with Windows 98 did not allow me to experience DOS. I have several books in front of me that pertain to the use of DOS and I have searched the internet but I am still stumped on how complete these files.
    The machine is running a fresh copy of Windows 98SE. Now I know that I do not need these files for Windows itself, but for DOS mode. I am going to be using DOS mode for gaming specifically.
    A few important things:
    -I am looking to get the most memory available for those memory hungry games
    -Machine is a P200 Dell GXi with integrated sound and video. Installed are an internal floppy (A), Western Digital HD (C), Zip Drive (Iomega I'm assuming) (D), and a generic CDROM drive (E). I am also using a generic PS/2 mouse.
    So far I have the following:
    DEVICE=C:\Windows\HIMEM.SYS
    DOS=HIGH,UMB
    DEVICE=C:\Windows\EMM386.EXE NOEMS
    As for the autoexec... well I am clueless on how to configure that
    autoexec.bat is the DOS equivilent of Start Menu > Startup. Programs like ACME Screen Saver would be put in here. An autoexec.bat file usually looks like this:
    echo off
    prompt $p$g
    if you have windows installed, then there's usually a WIN command at the end.
    there can also be a whole bunch of odd commands like MS-CDEX drivers, TSRs, ect. Treat autoexec.bat like a DOS command prompt. point it to where the program is (cd x:\dir\name\here) and then the filename and you're good.
    Last edited by linuxlove; May 10th, 2009 at 06:26 PM. Reason: accidently hit reply instead of preview
  3. Default
    here is a good tutorial, with recommendations on 3rd party software to improve DOS performance.
    http://www.mdgx.com/mem7.htm
    Okay, I appreciate the help guys.
    My config.sys now looks like:
    DOS=HIGH,UMB
    DEVICEHIGH=C:\Windows\COMMAND\EBD\oakcdrom.sys /D:MSCD0001
    LASTDRIVE=Z
    Autoexec looks like:
    @echo off
    LH: C:\Windows\COMMAND\MSCDEX.EXE /D:MSCD0001
    The CDROM works in Windows and is listed as an NEC drive. DOS however, will not recognize it. Any suggestions?
    30,665
    Does this produce any messages saying it can find the CDROM?
    Okay I have made progress! CDROM is now working!
    Autoexec now looks like
    @echo off
    SET SOUND=C:\Windows\System
    SET BLASTER=A220 I5 D1 H5 P330 E620 T6
    SET MOUSE=C:\Windows\System
    Config.sys is the same
    Three problems
    -Memory is now down to around 30k instead of 620,000 before I started tampering
    -Mouse does not work (I'm guessing I will need the mouse.ini file)
    -Games do not auto detect Sound Blaster. I have the manually specify the settings. The computer is running onboard sound.
    Thanks again guys
    30,665
    Run MEM /P from the DOS prompt and see what's sucking up the memory. Only 30K, not 300K?
      Name           Total       =   Conventional   +   Upper Memory
      SYSTEM    18,304   (18K)         10,608   (10K)       7,696    (8K)
      HIMEM      1,104    (1K)            1,104    (1K)         0    (0K)
      EMM386    4,320    (4K)            4,320    (4K)         0    (0K)
      DBLBUFF    2,976    (3K)            2,976    (3K)         0    (0K)
      WIN          3,744    (4K)            3,744    (4K)         0    (0K)
      OAKCDROM 36,064 (35K)            0        (0K)          36,064    (35K)
      IFSHLP      2,864    (3K)             0        (0K)          2,864    (3K)
      MSCDEX    28,032    (27K)         0       (0K)           28,032    (27K)
      COMMAND 7,168    (7K)             0       (0K)           7,168    (7K)
      Free         708,832  (692K)        632,352  (618K)    76,480   (75K)
    30,665
    Ah, you mean "memory used out of the base 640K" not "memory available". Sorry, I misunderstood.
  10. Default
    there should be no ":" after LH
    you have to load a DOS mouse driver. get ctmouse. add it to your autoexec.bat:
    LH \DOS\CTMOUSE.EXE
    aside from the SET settings you also need to load the soundcard drivers. get them here if they are SB PCI variant:
    easymamecab.mameworld.info/html/snddosdr.htm
    easymamecab.mameworld.info/html/sndhelp.htm
    in your bios, change "PNP OS" to NO or OFF.
