Results 1 to 10 of 13
Thread: Windows 95 on low specs
    5,996
    44
    Default Windows 95 on low specs
    I have finally secured an IBM PC110 Palmtop and im looking into installing Windows 95 OSR2 on it.
    The thing is that I have never really run Windows 95 on something with specs this low before.
    The PC110 has a 33mhz (I can jump it to 40mhz if that helps any) 486 SX and my particular PC110 will have 8mb of ram in it (though if you can find it, a 16mb module exists so you can max out with 20mb ram).
    Windows 95 is apparently supported on the Pc110 but I need to know first hand from someone just how slowly Windows 95 will crawl with that slow of a processor and that small amount of ram. I would go Windows 3.1 but I don't have much 3.1 software and the pcmcia cd drive I use won't work with anything older than Windows 95.
    = Excellent space heater
    My first windows 95 machine was less than that. 486sx/16 with 4mb of RAM. It was SLOOOW, but it was useable.
    my thinkpad is running Win95 OSR2 (i think) on only 8MB of RAM. As long as you make the install as small as possible, you can get 95 to wrok on a 486 w./8MB RAM.
    34,061
    If I turn my head about 90 degrees, I can see Win95 OSR2 running on a 16MHz 386 with 13MB of memory. It takes forever (seemingly) to come up, but works passably well.
    Hmm...from memory it will be slow. Mainly due to the 8MB memory. 33 Mhz and the 486 chip is adequate.
    Tez
    6,425
    8MB or higher is enough to run W95 comfortably. 4MB runs, but is extremely starved (takes over 10 minutes to boot and is always swapping).
    5,996
    44
    so pretty much the processor will be able to sustain the OS but the ram is right at the lower limit on what is acceptable. So should upgrading to 20mb help the system a lot?
    Also, I plan on just stuffing something like a 2 or 4gb complact flash card in it to spare me both PCMCIA slots.
    6,425
    Yes, 20MB RAM will run W95 quite comfortably.
    5,996
    44
    Thanks Trixter. It's a bloody same though they had to use a proprietary ram cartridge. :/
    I was also looking around here and I'm assuming it's slightly dates as a lot of the storage relies on a PCMCIA drive and not the Compact Flash drive so hopefully I can still pop in a higher capacity Type I CF card and not have any issues. Also, his macro shots for the overclock page are terrible. They almost want to make me go with mine and redo them.
    Sep 2003
    Ohio/USA
    7,959
    I had it running on a disczrded 486/sx 25 with 8MB of RAM in the 90's at work to run tests, it wasn't the fastest booting machine in the world but did run ok.
