Results 1 to 4 of 4
Thread: one question about the ti99
    Default one question about the ti99
    i put two 32k memory upgrades in one PEBox will that make the computer work/run better/faster ?
    The system will only recognize one of them--take the second one out, as it gives no additional benefit and may introduce problems. . .if you want more memory, you need to use something like the SAMS card (current source for these is Tex*In Treasures).
    Quote Originally Posted by Ksarul View Post
    Ok thank you much that is all i needed to know i took one out and put it away
    delete this thread
    Actually, threads like this one usually stay up to help answer the question when asked by others later. BTW, look on the Yahoo Groups and you will find many TI people to help you--the primary groups for TI people there are TI-99/4A for general stuff and SWPB for programming. . .
