Results 1 to 3 of 3
Thread: TIIF Help
  1. Default TIIF Help
    Anybody use this utility with their TI-74 PC Interface?
    Anyone know if you have to use the parallel or serial port to print directly onto a PC Printer? I only have a usb lead for my printer, is there anyway I can print to it without buying a new lead?
    I'm trying to print from a word processing document, but keep getting a "bad argument" error...
    Apr 2003
    Amarillo, TX
    1,168
    IF I remember correctly, it's strictly parallel.
    The other bad news is the author has moved on to other projects, so TIIF isn't supported at all. Strictly use at your own risk!
    Outside a dog, a book is a man's best friend. Inside a dog it's too dark to read! Groucho Marx
    Curtis McCain
    http://pages.suddenlink.net/curtismc/
    Default Tiif
    My serial/parallel port card works fine with PC-IF in
    my Dell 2100, Celeron 1.1 GHz, XP-HE), running VPC 2007.
    I have'nt tried to use the serial port yet, but it shows up
    in the VPC 2007 config screen.
    Jack
