Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 60
Thread: Just got a Performa 638CD need a ethernet card for it
  1. #31
    Sep 2003
    Ohio/USA
    7,967
    Some of the cheaper performa models went to IDE (I know the 6200, 6400, 6500 series was IDE while the Powermac 6100, 7100, 8100, 7500, 8500, 9500 stuck with SCSI).
  2. #32
    Jun 2003
    Bellevue, Colorado
    2,437
    Having IDE in there means I have a drive ready for it NOW. How big is the largest it can take, anyone know?? iirc I have a lower gig one around somewhere, maybe 6GB. Excellent news.
    Also, I'm going to give a slight upgrade a shot since I'm already at my max ram anyway.
    The ancients knew *more* than us...
    http://www.legendarytimes.com/forum/index.php They're baaaack!
    Come and see http://www.gamegavel.com for all your gaming needs! We have Zero-ohm resistors!
  3. #33
    Jun 2009
    St. Louis, MO
    436
    I don't know if there's a limit, but IDE harddrives can be pretty big. What I would wonder how to do is how to format it for a Mac and how to install the system software on it.
  4. #34
    Sep 2003
    Ohio/USA
    7,967
    Any OS install CD has the tools to format a HD (boot from the CD). The issue you have with Performa IDE drives is speed, they are not DMA enabled and probably ATA/16 (slowest) interface. Anything under 8gb should be plenty of space.
  5. #35
    Jun 2003
    Bellevue, Colorado
    2,437
    No chance to play with it today, but I do have a Seagate ST38421a 8.4GB ready to go in, and both the floppies and a disk image for the new OS. When I get the chance I'll get it installed.
  6. #36
    Jun 2009
    St. Louis, MO
    436
    Can you upload the OS disks? I want to install a new harddrive, but I need the install disks.
  7. #37
    Jun 2003
    Bellevue, Colorado
    2,437
    Sure, but I have to get everything imaged/copied first from a Mac-- I have done similar projects before, had bad results from windows. So please give me time and I'll upload the disks for you no problem. Soon, when I get the chance to get it done.
  8. #38
    Sep 2008
    Columbia, SC USA area
    589
    @Tupin:
    I also have quite a few OS versions, .8, 6, 7.5, 8, 8.5, 9.1 off the top of my head, maybe more
    Let me know if you need any
    Cheers!
    Wmmullaney
    Collection: Replica I TE, 3 Apple IIe, Apple IIgs, Apple Performa 630cd 68k, 4 PowerPC Performa, 2 Timex/Sinclair 1000 and 1500, PC/AT c286 clone, Commodore 64 and 128, NCR box with a 386 mobo, TRS-80 PC-2, DreamCast, PlayStation 1 and 2, 2 iMac G4, Powermac G3 beige and aqua, Twinhead 386, Toshiba T1910, Zenith zwl-183, set of Intel MCS-8 boards (CPU, RAM, ROM, I/O)
  9. #39
    Jun 2009
    St. Louis, MO
    436
    I finally got my card today, I plugged it in and it recognized it right away!
    I don't have an extra cable modem, but I'm getting that soon. I would be happy to have some of those OSes, but I can't seem to be able to burn a Mac-compatible disc on my PC.
  10. #40
    Jun 2003
    Bellevue, Colorado
    2,437
    Covered up with actual work, so no time to get to the fun stuff right now.
    @Tupin, I made a cd from my win pc, just made it as a data disk and it read fine; gave me the name of the disk an everything. Tip: burn slow. Also, I used Nero 6 as my burner program. The windows burn function has led to crappy results.
