Results 1 to 9 of 9
Thread: thinkpad LCD not showing right
    Default thinkpad LCD not showing right
    well i got my new LCD for my TP 360CE. Pop it in and 20 mins later it's all reassembled. When i turn it on however, i do not see a memory test. thinking this is because it's still on external monitor mode, i hit FN-F7 to switch to the internal LCD. Intead of seeing the Windows 95 boot screen, i see one line on the screen. I've reseated the screen cable and still no success. I know it is not a screen for a different type of thinkpad, because the part numbers on the broken screen and the new one both match. Only thing i can think of that might be wrong is
    A - Screen cable
    B - the board on the LCD. EDIT: Took apart the bad LCD and found that the LCD board is perminantly attached.
    Sep 2003
    Ohio/USA
    7,375
    Is the line bright? Could be a bad backlight?
    The backlight is fine and the line is a bright line.
    Also @ Unknown_K, those parts i was told i can't ship em to ya
    Sep 2003
    Ohio/USA
    7,375
    Quote Originally Posted by linuxlove View Post
    I asumed that a long time ago.
    Does the external video still work?
    yes it still does work. i also might think that the inverter board may be bad; i ran this laptop for some time with out a screen attached to the inverter board.
    I think, the panel is working, but my laptop is broken.
    oh if only the TP 360 repair manual didn't get deleted ;(
    Sep 2003
    Ohio/USA
    7,375
    Thats a shame, I have a 365c (486) and a pair of 365xd's (Pentium 1's) and they seem reliable enough. Unlike the 760 models I have had in parts and put back together the 365s mostly just needed work done on the LCD hinges.
    Jun 2009
    Lodi,CA
    285
    22
    Default Maybe Some Help
    I'll look at my Box-O-Holding for 360 parts,I might be able to help with something.Think Pads are normally too tough to die.
    cgrape2
    If the backlight works then the inverter is good.
