Page 40 of 41 FirstFirst ... 30363738394041 LastLast
Results 391 to 400 of 401
Thread: XTIDE Universal BIOS
  1. #391
    Hardware failure, should be back by the end of the week.
  2. #392
    Dec 2018
    Western New England
    16
    Quote Originally Posted by pearce_jj View Post
    Excellent! Thank you
  3. #393
    I see it's back up did you get the problems sorted, Can it be updated with new revisions now ?
  4. #394
    Yes but only if they don't have additional files for reasons that remain unknown
  5. #395
    Dec 2018
    Western New England
    16
    I was able to update my XTIDE BIOS, but then hosed it with a bad configuration. I was trying to set the BIOS display to monochrome, and now all I get is crazy snow on boot. Since it won't boot from disk, I don't know what to do. Any thoughts?
  6. #396
    Replied on the other thread.
  7. #397
    Does anyone happen to have a copy of the XTIDE bios already split into even / odd (in BIN format?) for U17 & U37 on an IBM 5170 motherboard? I have a couple different ISA cards, and it works great in those - but I thought I would give this a try next. I'm still researching the best way to properly split the file.
  8. #398
    Turbo Pascal
  9. #399
    Quote Originally Posted by jasmi View Post
    I posted a copy of r591 with boot menu a while back for the U17 and U37 sockets, It's configured for a 16-bit IDE controller, Give that a try if you want, See post #120, http://www.vcfed.org/forum/showthrea...estions/page12
    Are you aware of the incompatibility of the XUB and the IBM 5170 BIOS, See Modem7's site, http://minuszerodegrees.net/xtide/XT...20Problems.htm
  10. #400
    May 2006
    Melbourne, Australia
    6,018
    ... for U17 & U37 on an IBM 5170 motherboard?
    Welcome to these forums.
    As was recently discovered ('rediscovered' is probably more accurate), any BIOS expansion ROM code (such as the XUB) for the IBM 5170's sockets U17/U37 needs to be 64 KB sized.
    A simple Windows utility to create the odd and even components (and go the other way, a merge) is at [here].
Tags for this Thread
