Results 1 to 4 of 4
Thread: ethernet in ELKS?
    Default ethernet in ELKS?
    i've got ELKS installed on a hard drive in my XT clone. it's very cool, but it looks like the TCP stack in it only likes to work over SLIP on a tty. i can set up a SLIP link with my linux box and bridge, but is there any way to set up and use an ethernet card with it instead?
    that would obviously be much better. i have a NE1000 clone in it.
    if not, does MINIX 1 or 2 support ethernet? i think it does iirc, but forget if it has an httpd.
    Jul 2003
    Västerås, Sweden
    6,275
    Minix 2 seems to support some Ethernet cards:
    http://minix1.woodhull.com/faq/ethcards.html
    As for ELKS, as far as I can find it is still pretty much a DIY OS. There are links to a TCP/IP stack but it does not seem to integrate by itself into the operating system.
    Anders Carlsson
    Quote Originally Posted by carlsson View Post
    thanks for the link, i took a closer look at minix 2. i've got it installed and recompiled the kernel for TCP/IP support. working nicely! i was able to set up swap space thankfully.
    Quote Originally Posted by Mike Chambers View Post
    Bringing up an old post here but what are the specs on your XT that you ran this on. cpu? ram?
