Results 1 to 4 of 4
Thread: AIX 4.3.2 on Motorola Powerstack II
    Default AIX 4.3.2 on Motorola Powerstack II
    The Installation (didnt tried any further) work fine, if I'm using a serial terminal. For this I have to unplug the keyboard and the mouse. Furthermore the graphicscard has to be removed.
    When I want to install it without the serial terminal, the installation will hang before I can enter anything. It seems, that the machine executes the installer, but all I can see is the initial firmware screen.
    As referring to the OpenFirmware Dokumentation, I have a graphicscard, which is supported:
    Card					Chipset
    Datapath   Tornado			Weitek 9100
    Diamond Multimedia Viper Pro Video 	Weitek 9100
    Motorola   Prolink 5434			5434
    Univision  Aurora          		S3 968/VRAM
    Mine is a Miro Video 20SV, which is a S3 968 including VRAM.
    Any suggestions?
    Thanks in advance.
    Nobody?
    Despite having the same chip, yours is not Univision Aurora.
    You need to get one off the list, look up "Card" field, not "Chipset".
    Default Motorola Powerstack II CD media
    Quote Originally Posted by TNC View Post
    Card					Chipset
    Any suggestions?
    Thanks in advance.
    I have Motorola AIX 4.32 system. nut It crash down last week. I can't boot from CD , because CD media is dead. Can you get CD ISO form you ( 82-1243 )? hyweiac@gmail.com
