Page 112 of 112 FirstFirst ... 1262102108109110111112
Results 1,111 to 1,118 of 1118
Thread: XTIDE tech support thread
  1. #1111
    Feb 2017
    Chilliwack, BC, Canada
    535
    Is there a thread yet dedicated just to listing compatible devices with the XT-IDE and ISA-CF cards?
    Compact Flash, DOM, Hard Drives, CF-IDE adapters, SD-IDE adapters, and so on. Which are known to work, which don't, with which card, what XUB version, etc?.
    If not, I think it might be worth making one. Post pictures of the devices that work/don't work, maybe benchmark specs if you'd think them relevant, that kind of thing.
    Most I've heard about work, but if there's any known to have issues, it would serve as a "buyer's guide," so people know which ones are known to be reliable and which are to be avoided for use with these cards.
    My vintage systems: Tandy 1000 HX, Tandy 1000 RSX, Tandy 1100FD, Tandy 64K CoCo 2, Commodore VIC-20, and some random Pentium in a Hewitt Rand chassis...
    Some people keep a classic car in their garage. Some people keep vintage computers. The latter hobby is cheaper, usually takes less space, and is less likely to lead to a fatal accident.
  2. #1112
    Oct 2017
    SE Michigan, USA
    574
    I used a Syba CF2IDE adapter with a 4GB CF Card using my Packard Bell Pack-Mate 28 Plus with the IDE adapter connected to the primary (local bus) IDE and secondary (ISA) IDE and it worked without issues.
    Current retro systems:
    Commodore 64 Breadbin 250407 Rev. C
    Toshiba Satellite Pro 410CDT, 2x IBM ThinkPad 380D (TFT and DSTN)
    iMac G3/600 Graphite, iMac G4/800 Lampshade
    YouTube channel: https://www.youtube.com/c/RetroPCUser
  3. #1113
    Quote Originally Posted by blackepyon View Post
    Back in the early days when the XUB home was on the old google code site there was a "Drive compatibility" page and a "Benchmark" page, It's a good idea but i'd recommend listing system specs as well, ie: Make - Model - System Bios details. What works in one system may totally crap out in another different system. I don't recall a specific thread ever being started other than the XUB hardware thread on here, There's probably loads of "What works and what don't" scattered all over the place on this forum.
  4. #1114
    Feb 2017
    535
    Quote Originally Posted by Malc View Post
    I started a thread here: XTIDE Device Compatibility List
    If anybody has a list/pictures of the CF cards, adapters, and whatnot that they've tested that they'd like to contribute, feel free to pitch in!
  5. #1115
    I have both a Rev. 3 and a Rev. 4 XT-IDE board, and neither boots into the XT-IDE menu on my AMIBIOS motherboard. It's a 486 motherboard with three VLB slots, the rest are ISA.
  6. #1116
    Feb 2017
    535
    Quote Originally Posted by Sir_Fartalot View Post
    Check the AMIBIOS settings to make sure it can support booting from external or 3rd party (ISA/VESA card) ROMs. I haven't used an AMIBIOS in years, so I don't remember exactly where the setting would be, it might even show up as a LAN boot ROM or something. I think (and since it's been a while, I might be wrong) that the VESA motherboards handled the IDE and I/O controller cards through the motherboard's BIOS, rather than a ROM from the card, so it might not have been set up for it.
  7. #1117
    Thank you - I did try to look for something of that nature, but could not locate or determine anything appropriate. Anything to do with shadow RAM, maybe? Maybe I also have to change the default ROM address on the XT-IDE? What you say about the VESA motherboard handling the BIOS for the I/O controller directly sounds interesting, and it also might have something to do with the ROM address on the XT-IDE. This coming week-end I will try another motherboard with the XT-IDE cards.
  8. #1118
    Feb 2017
    535
    Shadow RAM just copies the BIOS into RAM so it can be accessed quicker, so I doubt it.
    My money is on the BIOS just not looking for option/LAN boot ROMS. What's the make/model of the motherboard?
    Well, good luck. I'm really just shooting in the dark here. As I said, It's been quite a while since I've played with a VESA motherboard.
Tags for this Thread
