Results 1 to 7 of 7
Thread: Kaypro boot disk's .BAS games
    Aug 2009
    Sunnyvale, California USA
    85
    Default Kaypro boot disk's .BAS games
    I just got my Kaypro up and running. I am curious of how to load and play the .BAS games in the boot disk. The boot disk also has MBASIC.BAS too.
    Doug
    Jun 2009
    Sebring, Florida
    61
    3
    Are you sure it is not MBASIC.COM? I recall that some of the Kaypro BASIC games required OBASIC instead (e.g., Star Trek). If you are trying to run a program in either MBASIC or OBASIC, run MBASIC/OBASIC. Load the program by typing load "filename.bas" and then, once loaded, type run "filename.bas"
    Quote Originally Posted by Dougtronics View Post
    Let's hope you mean MBASIC.COM
    From the CP/M prompt:
    A>MBASIC B:FOO.BAS
    From inside MBASIC:
    A>MBASIC
    BASIC-80 Rev. 5.21
    [CP/M Version]
    Copyright 1977-1981 (C) by Microsoft
    Created: 28-Jul-81
    34872 Bytes free
    Ok
    FILES"B:*.BAS"
    (listing of programs with .BAS suffix)
    RUN"B:FOO.BAS"
    (or)
    LOAD"B:FOO.BAS"
    RUN
    (also try:)
    LIST
    Have fun,
    Andy
    "It's a me-too, 8-bit machine with good graphics and a disk system nobody will support."
    -- Bill Gates, about the Sony SMC-70 with the new 3.5" floppy drives (InfoWorld; June 7, 1982)
    Aug 2009
    85
    Chris and Andy,
    With your help I am able to play BLKJK.BAS, Black Jack Las Vegas Style all night long. I have tried the command FILES, LIST, LOAD and RUN. I play the game with the disk in A drive. I have not figure out how to copy the game to the disk in B drive and play there yet. The will be the next project.
    Doug
    You should try SBASIC too, that was on my Kaypro boot disk. That's a Basic compiler just like CBASIC, and it will make the programs zoom. I don't think every Basic program will compile on there since it was made for a VDU display on the Kaypro instead of a serial terminal. So you may have to make a few tweaks with some of the PRINT statements.
    =Dan
    Dan Roganti
    my corner of cyberspace http://www.rogtronics.net/blog
    Vintage Computer Federation http://www.vcfed.org/
  6. Default
    Chris and Andy,
    Doug
    To copy the file your going to use "pip".
    ~Mark
  7. Default
    Hi friends,
    Any one know where I can download a Basic-80 image my one is damage.
    I check in Dave website, but this one is not there.
    Thanks
