Results 1 to 10 of 20
Thread: MS-DOS.. ECHO without a newline?
    Mar 2009
    DE, USA..
    2,701
    Default MS-DOS.. ECHO without a newline?
    I want to print the output of a program as part of an echo statement without having to redirect I/O to and from a file, because that slows things down unnecessarily.
    Basically I just want the comp to:
    echo This machine is powered by an `chkcpu/s`
    The only problem is the lack of backticks. So if I could do echo without a newline, then I could just run chkcpu/s and it would tack it on. My first thought was to print a backspace character to kill the newline, but I wasn't sure how to do that.
    Ideas?
    Resident Self-Proclaimed 486 and Pentium-class Machine Expert
    More commonly known as "Yushatak"
    www.yushatak.com
    Jan 2009
    Palm Springs CA
    708
    19
    Quote Originally Posted by Raven View Post
    Ideas?
    As far as I can tell 6.22 wont do it... Perhaps thru a PAUSE, but not by ECHO...
    FWIW...
    Mar 2010
    Florida, USA
    1,944
    What is the typical output of the chkcpu /s command?
    Moving forward without that info... I don't think you'll have success using a single-line solution, such as "chkcpu /s | echo This machine is powered by an "
    Does chkcpu return an errorlevel code that identifies the CPU? Does it give multiple lines of output? A single line? If an errorlevel, then a simple @chkcpu /s (to hide program output) and an if..errorlevel command to echo the correct output should take care of it.
    If not, a trick I've used in the past, while not elegant, certainly gets the job done if you have simple output. Send the program output to a small text file, then use a for command to parse the text you need out of that file. I had to use this trick to check the copy success of a backup script I wrote for XP Pro some time back. The output of a successful single-file copy command should always begin with one, so my commands were essentially:
    @copy file1 file2 >> temp.txt
    set data=0
    for /f %%x in (temp.txt) do set data=%%x
    if "%data%"=="1" goto copy_success
    goto copy_error1
    Again... far from elegant, but that backup script works like a charm.
    *edit - just realized that /f wasn't available with the for command in MS-DOS 6.22 (though I think it was in 7.0, i.e. Win95 DOS). Regardless, for the single-character search (or single-word search), the above code should work fine, removing the /f, of course.
    Currently seeking:
    I think I wrote something in Turbo C back in the day to do what you need done. I also remember finding that someone had a better "echo", maybe "xecho" is it:
    ftp://ftp.simtel.net/pub/simtelnet/m...l/xecho133.zip.
    The date on the executable inside is from 1998. Sadly, as an external executable, it's going to slow things down, too, compared to the command.com built in.
    Jim
    Whee!
    @echo off
    for /f "usebackq delims=" %i in (`chkcpu /s`) do set mycpu=%i
    echo This machine is powered by an %mycpu%
    You're welcome.
    Apple ][+ through iMac i5, 5150 PC through dual Xeon W5580 and quad Itanium 9150M, and many in between.
    Newton, Palm V, N-Gage, Tapwave Zodiac, iPhone, iPhone 7.
    Intellivision, Game Boy through 3DS, Wii, XBone
    24,123
    Try the attached--it not only omits the CR-LF, but allows you to echo any 8-bit character. Included is a similar utility for printer output.
    (P.S. to Mike--yeah I know it's a huge 232 bytes long, but it was 25 years ago and I was still getting my bearings in MS-DOS programming)
    Attached Files Attached Files
    Dec 2005
    Toronto ON Canada
    6,650
    Are you talkin' to ME??
    Heck, I use an old PC-MAG(?) utility called EMIT and it's a HUGE 13780 bytes (it does have a lot of options though); adding yours to my toolbox.
    Ideas?
    Risking to appear un-modest, i would like to advertise my DOSUTILS package, which you can download from here: http://www.bttr-software.de/products/jhoffmann/
    The utility PIPESET can do (to a relatively high degree) what the backticks would do under UNIX.
    Alternatively you could "abuse" the TIMESTMP utility as a replacement for echo. Specifying the /O switch would suppress the trailing newline, which i introduced for exactly the same purpose as you just need.
    Correction, I should have used double percents:
    @ECHO OFF
    for /f "usebackq delims=" %%i in (`chkcpu /s`) do set mycpu=%%i
    Assuming "chkcpu /s" produces the output you want, of course, with no LEADING newline.
    Dec 2005
    Toronto ON Canada
    6,650
    Quote Originally Posted by Anonymous Freak View Post
    Yeah, I was wondering about that. Worth mentioning that this won't work with any 'real' version of DOS, which kind of restricts its use as a universal CPU detector...
