Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Arachne fails to launch
  1. Default
    Quote Originally Posted by kishy View Post
    Hi all
    I'm attempting to run Arachne (1.95;GPL,286-) on my 286. 10MHz CPU, 2.6MB of RAM (640KB on the mobo, 2MB on ISA card). MS-DOS 6.22. Adaptec SCSI card with 1GB HDD (partitioned appropriately).
    It is for a newer one than 286 PC I guess, but there might be some clues:
    http://www.compmiscellanea.com/en/ar...p-ethernet.htm
  2. Default
    I'm having the same problem as the OP. Running 1.95/286 on a Compaq Portable II, 640kb RAM. Installed fine, then goes "Arachne is taking off" and sits there forever. Was the cause of this ever found?
  3. #23
    Quote Originally Posted by Fallingwater View Post
    Arachne needs a lot of free memory so perhaps look at that. I haven't tried 1.95/286, but looking at the readme for 1.70 I see that requires 500KB free memory, and 560KB if you are also running the built in PPP dialer.
  4. #24
    I'll throw my notes on Arachne here.
    After checking out that link, it looks like that version of Arachne is for 8088/286, I think I tried that a couple years ago (or maybe it was 1.93), on my GEM 286 computer. I was having trouble getting it to work for some reason. Maybe I'll retry tomorrow if I have time and repost.
    I'm running Arachne 0.73 with the really really old Arachne 8088/286 real/286 protected mode APM file installed. I have a video of it on youtube under the name "Internet on a 286" or something like that (alias, Creepingnet). I would be willing to put this up as an upload as it's the only working install of it I've seen on a 286 thus far.
    One thing I found on my computer that Arachne likes to use EMS/XMS driver if you have HIMEM.SYS loaded on your 286. That really boosts performance and makes the chance that it will run more likely.
