Page 11 of 11 FirstFirst ... 7891011
Results 101 to 109 of 109
Thread: Anybody here actually collect Unix stuff?
  1. #101
    Nifty
  2. #102
    Okay, now I'm having a problem. I'm trying to install the Developer Tools. I have a DEC RRD45 CD-ROM, which is just a re-ROMmed good old fashioned Toshiba XM-5401B in 512-byte sector mode. This drive works fine to boot the Solbourne S3000, so it's known good. It's on SCSI ID 6, the SCSI2SD is on SCSI ID 0.
    The Galaxy installed NeXTSTEP 3.3 from the RRD45 yesterday as shown and boots fine from the SCSI2SD without any issues. So far so good.
    Today, however, when I tried to bring it up with the CD-ROM connected and empty, it hangs. A verbose boot says it's stuck at "Please Insert SCSI Disk 0 in Drive 0." (It saw both the CD-ROM and the SCSI2SD; it put the CD-ROM on sd0 and the SCSI2SD on sd1.) I put in the Developer CD and it gets partway through the boot before throwing an error that syslogd is unhappy about the volume being write-protected (!) and the whole thing freezes at starting lookupd. I can cancel this with ^C, but then other things start going wacky, so I shut it down.
    If I start it with the CD-ROM connected and the Developer CD installed, then it does the same thing.
    If I shut down from the power switch, disconnect the CD-ROM and boot from the SCSI2SD alone, it's happy.
    What gives? Do I have the wrong SCSI IDs? The hard disk I removed was set to ID 6; the SCSI2SD is ID 0 and the CD-ROM is ID 6. Before I go futzing around with trying different combinations, what are the IDs supposed to be? I know the SPARC version wants the CD-ROM on 6 and the primary drive on 3, but I can't find any documentation whether the PA-RISC port is the same way (or for that matter, much documentation on the PA-RISC port, period).
  3. #103
    Yeah, I believe the PA-RISC version is similarly anal about SCSI IDs. For myself, though, if memory serves I just got tired of screwing around with getting the CD-ROM to coexist peacefully and copied the files over the network. *checks* Ah, yes. I have a thread about it over on irix.cc, but in short, the mount command in modern Linux has a "ufstype=nextstep-cd" option that allows one to mount NS ISOs directly. From there, just tar-ing up the contents of the CD and moving them over to the HP was enough to install the tools from.
  4. #104
    That at least gives me a means to install it, but since the PA-RISC port seems rather unloved (thank goodness for quad binaries), I'll poke around and see if I can figure out what the magic is when I get some time later. My working theory based on what was previously installed is that drives should be installed in descending order with the primary starting at 6 and CDs lower.
    Oh, and gotta get OmniWeb on this thing too.
  5. #105
    I hate being right. SCSI2SD set to 6, CD-ROM set to 3, genius.
    https://www.floodgap.com/iv/3781
  6. #106
    Jun 2007
    Wisbech, CAMBRIDGESHIRE, UK
    369
    I've got a Sun SPARC Enterprise 1 running Solaris, an IBM RS6000 Model F50 running AIX, and an HP K-Class 9000 running HP-UX.
    My vintage Computer Museum. Please visit.
  7. #107
    Oooh, a K-class. My first job out of college was on a K250 running 10.20. I remember a lot of hacking to make aCC happy.
  8. #108
    Nov 2016
    Quakertown, Pennsylvania
    350
    I picked up a Sun Ultra 1 at VCF East. 167MHz UltraSPARC, 256MB RAM, running Solaris 8.
    https://i.imgur.com/ZlsV48m.jpg
  9. #109
    The Ultra series was my introduction to RISC workstation hardware. Aside from the inevitable proprietary peripheral ports, they're not bad machines.
