Results 1 to 10 of 15
Thread: Floppy controller ID
    Default Floppy controller ID
    I recently picked up another Imsai and it came with an external
    floppy drive(s) and controller card. I haven't been able to find
    any doc's on the controller; Micro Applications INC. 2100.
    http://home.mchsi.com/~litterbox99/temp/floppy.jpg
    I'd like to know more about it before I power it up.
    I was able to ID the drives, two Shugart 400's.
    I don't know if there mini's, they measure about 3" 1/2
    tall.
    http://home.mchsi.com/~litterbox99/temp/drive.jpg
    The drives are clean, but it looks like the power supply
    has had a few rectifiers replaced and there is evidence
    of burning on the PCB. I have a switcher that is just the
    right size I'll drop in.
    It came with 14 floppy disks labeled Dos, Basic, Games,
    monitor and etc... These disks have more than one index
    hole, like 10 of them, so from what I gather, they are hard
    sectored ?
    Is a Shugart 400 a soft or hard sectored drive ?
    or is this controller dependent ?
    I'm not sure if the disks & drives are original to the Imsai.
    Yeah ! more to learn
    The SA400 was used in the Northstar MDS floppy drive. In this application they were hard-sectored. I have two of them attached to my IMSAI.
    Here are a couple of docs which may be useful.
    http://home.comcast.net/~kvaughn65c/..._OEM_Sep78.pdf
    http://home.comcast.net/~kvaughn65c/...vice_Apr79.pdf
    I looked at the eBay listing. It mentions Northstar system software. This is an area where I can help. My IMSAI is a PCS 80/30 with a MPU-B Board (8085 CPU). I used two different disk controllers -- a Northstar MDS (single density) and a MicroComplex Controller (double density). The MicroComplex board is in the system today. I bought my IMSAI (new) in 1977, and I used Northstar DOS mostly in the first year or two. I started with DOS 3.x if my memory serves me, and upgraded to 4.0, 5.0, and 5.1. I wrote a great deal of software which ran under DOS, including a macro based higher level language.
    I also used CPM (V1.4 and V2.2) and the UCSD Pascal P-code system with the Northstar Drives. In the past few weeks I have been installing various CP/M 2.2 applications. I have been able to bring up Wordstar/SpellStar and CompuView Vedit, both of which drive the video controller card (VIO-C) in its native (memory mapped) mode of operation. I also have been able to install and run MBasic (interpreter), as well as the BASCOM (compiler) and the Fortran-80 compiler. There is a lot of software available in the Northstar format.
    I have a great deal of of documentation (scanned to PDF) on the software I used. When your system is operational, I can provide links.
    Thanks for the info Ken.
    Learning something new every day with this hobby.
    Now for some more questions...
    Will I be able to 'boot' from any of these disks ?
    Or will I have to toggle in a loader? From what I
    have been reading, I understand it goes both ways.
    The controller looks like it has a bipolar ROM labeled
    'boot' Does this prom have the loader or is it stored
    like a boot sector on the disk ?
    Or do I have to jump to an addy, the seller mentioned
    something about he could never get DOS going and
    referenced jumping to $E900 with no results...
    New blank media.
    I did some searching and it doesn't look like you can
    buy hard sectored (10) 5 1/4 disks. I did see on another
    forum where they talked about making a punch jig. I wouldn't
    have a problem with this if I could buy some media to modify.
    That should be enough for now
    Todd
    Hi Todd,
    I'll take a shot at answering your questions. First, let me lay out some assumptions. It would appear from what the seller said, and from the list of manuals, that the 14 diskettes contained Northstar DOS and the Northstar Basic interpreter software. My guess is that this was probably an earlier version of DOS, probably single density. I don't know whether the disk drives themselves were manufactured by Northstar, but that is quite possible. Northstar provided their MDS disk system to IMSAI and other S100 manufacturers. I have no knowledge of the controller card, but it could Northstar MDS compatible, as my MicroComplex controller is. The seller said that he was not able to get the disk drives to boot from a floppy, so it is not clear if the hardware is working or not.
    Q. Will I be able to boot from any of these disks?
    A. All depends on how they were created. A floppy may or may not contain a copy of DOS on the diskette. If it does not, then you would not be able to boot from that particular diskette. It was common practice to put a copy of DOS only on certain diskettes, and those were the ones from which the system was booted. Others might have been used primarily as data storage diskettes. Once DOS was loaded into RAM from a bootable diskette, that diskette could be removed, although it was common practice to keep a bootable diskette in drive 1.
    Q. Will I have to toggle in a loader?
    A. If the hardware is working, and the diskette(s) contain DOS, you will not have to toggle in a loader. The bootstrap software is contained in ROM on the controller card. Northstar diskettes which were properly initialized (formatted) contained the disk catalog (directory) in sectors 0-3 on the first track. If the diskette contained Dos, it would start in sector 4 on the first track, and would be 10 (single den) or 6 (double den) sectors in length, depending on the version. The bootstrap loader in ROM would read the first sector of Dos into a specified RAM location, usually $2000 and then branch to a given routine which would load the remainder of Dos. A sector contains 256 bytes on a single density diskette, and 512 bytes on a double density diskette.
    Q. Do I have to jump to a given address?
    A. Yes. On Northstar single density controllers this address was usually $E900.
    On double density controllers, the address was usually $E800.
    The seller mentioned that a jump to $E900 caused the disk to spin if I remember correctly. That would indicate that it was trying to boot.
    Q. Can I still buy 10 sector hard sector diskettes?
    A. This has been discussed in previous posts. They are still available from an outfit in Calif. The name escapes me at the moment, but I will look it up. I seem to recall a price of $35 per box of ten. The jig that you mentioned was made available to forum members by Dwight Elvey. I bought one and it works pretty well. Contact Dwight to see if he still has any for sale. This jig requires 360KB (soft sector) media.
    Ken
    Edit: The supplier of 10 sector (hard sector) diskettes is Athana.
    Thanks Ken ! something to digest...
    It's funny you mentioned $2000, this system is configured
    for memory starting at $2000-$9FFF with various memory boards.
    Looks very promising
    I never did understand why some S-100 systems with DOS or
    CPM start at an odd addresses above 00h. In my mind, I would think
    you would start at 00h and work your way up.
    Thanks
    Todd
    Hi
    The drives don't know hard from soft sectored.
    The controller determines hard/softsectored.
    400's are FM drives and single sided.
    Quote Originally Posted by litterbox99 View Post
    Thanks
    Todd
    Hi
    If the system has no way to swap out the ROM on boot,
    it can't have RAM at zero.
    This was not all that uncommon for systems other than CP/M
    to have RAM starting at something other than 0.
    CP/M wouldn't have started with RAM at 0 if it hadn't
    been developed on a Intel developement system that
    had the ability to swap the ROM out. While you see it
    as a flaw of the other systems, I see it as a flaw in
    CP/M.
    Hi
    CP/M.
    All very true. By the time that IMSAI developed the MPU-B board, which I use, they provided an option in the Monitor program to disable the (ROM at $0000/on-board RAM/system timers) before jumping to the bootstrap loader in ROM on the disk controller board.
    The CPU-B was sort of strange in that the monitor ROM which appears at $0000 also appears at $D800, and it is tied to the timers which I have to enable momemtarily in order to program the baud rate on the 8251 UART. They only exist in address space for a few instructions, after which they are disabled -- but this caused me some problems when I was bringing up a 56K version of CP/M 2.2. The monitor ROM at $D800 and my code in CBIOS collided with each other while I was setting up a timer. Had to drop back to a 55K system to avoid the conflict.
    Todd
    Let's hope so -- but there are still some issues to resolve. I was going to mention this in my previous post, but it was getting pretty long and I decided not to muddy up the waters.
    The diskettes you have, and which we assume contain N* DOS, are configured for some sort of console. Without a working console, DOS cannot talk to you; and without a working DOS, it is difficult to configure the console. Unless I missed something, your system did not come with a console (usually some sort of CRT terminal connected to a serial port). My IMSAI, on the other hand, uses an intelligent keyboard connected to a parallel port, and a monitor connected directly to the video card to provide the system console. Unlike many "off the shelf systems" which were to follow, the IMSAI usually did not come with a console.
    The system console must be implemented in the BIOS portion of DOS. There are four jump vectors in DOS which point to routines in the customized BIOS, specifically:
    at $200D -- a jump to your character out routine (could be as little as 6 instructions)
    at $2010 -- a jump to your character input routine (could be as little as 6 instructions)
    at $2013 -- a jump to the routine to initialize your terminal, if required, or a simple return
    at $2016 -- a jump to the routine to handle a control-C abort
    These routines are located in an area which DOS provides at $2900. Your DOS manual covers all of this and has a sample BIOS. This is not complicated, but may be a little intimidating the first time you have to do it. CP/M and UCSD P-Code systems require that a similar BIOS be provided.
    Those great looking toggle switches, and those blinking lights on the front panel are sure nice to look at, but to do some useful work you must have a console of some sort or another. If your DOS was configured for a terminal on the serial port, and you have such a terminal, then what you have may work.
    Ken
    a photo of my old IMSAI
    http://home.comcast.net/~kvaughn65c/imsai_pcs_80_30.jpg
