Results 1 to 10 of 13
Thread: 2600-on-a-chip
    Jan 2009
    At my computer
    632
    Default 2600-on-a-chip
    Hello everyone!
    Well, for christmas, my ever-observant grandmother picked me up an interesting bit of technology: an 'Atari Flashback 2'. It appears to be an incredibly small 2600 lookalike that plugs into a TV via RCA. After some googling, it appears that this is in the same vein as the C64 DTV, which is a C64-on-a-chip. It also appears that with some cheap parts and a steady hand (as well as some more flux), I can add a 2600 cartridge port to this. But why stop there?! I might get some NiCADs and make it battery powered, find an old dvd player, and hook up the screen for a portable Atari 2600!
    </pipe dream (yeah, like I'll have money for that >
    Anyways, has anyone here messed around with these before? The included games are pretty nice, and the inclusion of Pitfall! means I'll be spending a WHOLE lot of time with this thing and it's two (really well-built) clones of the original joysticks (!!!).
    [..RETRONET..] http://www.retro-box.net
    IRC, FTP, HTTP and Quake!
    Check us out (we have cookies)!
    Mar 2009
    DE, USA..
    2,750
    I had one, but I sold or traded it. I didn't know it could be modded like the 64DTV, or I may not have (though I'm terrible at soldering, so..).
    I did keep the controllers, though - newer build, slightly different, but still nice quality when compared to the original A2600 controllers.
    More commonly known as "Yushatak" - www.yushatak.com
    Focused on 486 and Pentium Machines
    I collect All-In-One PCs and Keyboard PCs, especially Compaq.
    Jul 2009
    Colfax, CA, USA, Grid Square CM99mb
    297
    The ones I'm familiar with aren't actually a 2600 on a chip, but a Nintendo on a chip that's been programmed to play 2600 games. Therefore it's not possible to add a cartridge port, it's only emulating a 2600.
    Yours may be an exception, but all the ones I've seen have been the Nintendo act-alike.
    Mark, W8BIT http://saundby.com/
    May 2008
    Alabama
    95
    Quote Originally Posted by saundby View Post
    I think you are thinking of the original Flashback, which was modeled to look like a miniature 7800.
    Exactly, the original Flashback was a NOC and played bad versions of 2600 and 7800 games. The Flashback 2 is a genuine 2600 implementation and extremely accurate. As was stated, even the two joystick ports are basically the same, and you can use the joysticks it came with on original systems or use other controllers on the Flashback 2. It's a shame it wasn't the Flashback 2 that was first. Honestly, though, unless you were desperate for a project, I wouldn't bother putting a cartridge port on the Flashback 2. You're better off getting a real Atari 2600 or 7800 and adding composite or s-video out.
    Bill Loguidice, Author
    Managing Director, Armchair Arcade
    About Me
    Jan 2009
    At my computer
    632
    Quote Originally Posted by Bill_Loguidice View Post
    But then it wouldn't be as small and easy to make portable. Remember the Picodore 64? It was a C64-on-a-chip turned into a large gameboy-advance-sized portable. That's sorta what I'd like to do with my Flashback 2...
    Mar 2010
    Florida, USA
    1,945
    Best Electronics has a guide for the cartridge mod on this.
    I suspect that it would be possible to implement this as a portable, however, the size of the portable would be questionable. It's been awhile since I looked at my unit, but it's about the size of my 2600Jr version (the redesigned model that looks like a miniature 7800). I'd guess that the motherboard in this unit has pieces that we can't cut off (if anyone's looked at Ben Heckendorn's mods, he ends up cutting off about a third of the 2600Jr's motherboards for his portable 2600's). If we can't reduce the size of the motherboard, we're looking at a larger system.
    Is that a problem? Not necessarily - I personally like the width and height of my Lynx-II, and this board is about that wide. I do wish it were a bit thinner, however
    Oh, and for portable DVD screen... do you really want to go there for a portable? - those are kinda large So long as you can get NTSC composite video and audio out of this thing (don't know, haven't looked at mine nor researched it - an electronics genius I am not), but I would suspect that the lcd used for upgrading a Sega Nomad's screen would suffice (so long as you didn't want a screen larger than 3.5"). That board has clear solder pads that will provide your ground, power, and composite video.
    (I was just looking up Sega Nomad screen upgrades a little earlier today)
    Currently seeking:
    Jan 2009
    At my computer
    632
    Quote Originally Posted by Maverick1978 View Post
    Since handheld 2600s have been done to death, I was going to make it a 2600 laptop, with a 6 or 7 inch screen.
    Also, I'm too much of a n00b to solder traces to shrink the board enough for a pocketable device
    Jun 2003
    Bellevue, Colorado
    2,437
    Make sure it's an actual one, this past Christmas there was a rash of counterfeit FB2's sold not by Atari but by some pirate company.
    http://www.atariage.com/forums/topic...sighting-2499/
    That is the thread discussing the fact that they are pirated and the differences to look for.
    The ancients knew *more* than us...
    http://www.legendarytimes.com/forum/index.php They're baaaack!
    Come and see http://www.gamegavel.com for all your gaming needs! We have Zero-ohm resistors!
    Jun 2007
    Milwaukee, Wisconsin
    Best Electronics
    Already done a while ago. Ben did one as well.
    It's a composite based plug and play.
    Why on earth go that route when you have places that sell composite based LCD's like this?
    http://www.aeicomp.com/search_result...LCD%20Monitors
    Marty
    Atari Gaming Headquarters
    Electronic Entertainment Museum (E2M)
    Midwest Gaming Classic
