Results 1 to 3 of 3
Thread: Tandon TM100 spinde motor speed problem
    Default Tandon TM100 spinde motor speed problem
    Hi all!
    My Tandon TM-100-2A is having problems with the speed of the spindle.
    Spinde speed will not stay constant no matter how I adjust. After adjustment I can somtimes get the drive to format and read/write. The next time I turn on the machine I have to reapet the adjustment.
    Any ideas?
    Maybe the servo board is failing, I experienced a similar problem and I fixed it replacing some components:
    You can read it in this thread.
    Good luck!
    31,821
    Also, check for bad bearings or a slipping belt. Both happen on old drives.
