Results 1 to 4 of 4
Thread: Trouble booting MS-DOS 5.0 to hard drive
    Northern VA - USA
    202
    Default Trouble booting MS-DOS 5.0 to hard drive
    Hopefully I am missing something obvious, maybe you can help?
    I am in the middle of a couple vintage systems, this is a 386 that I am putting dos 5.0 to start on. I have installed dos 5.0 (from the three install disks) and cannot get it to boot off the hard drive.
    Setup:
    DTK PEM-3335D mobo, 386-DX33 & NPU, 8mb RAM, 64k cache.
    Future Domain ide/fdd controller + multi I/O
    WD Caviar 420mb HD + 1.44mb FDD.
    Problem:
    This mobo bios has no "user-define" or "auto-detect" option for the drive type.
    Using drive-type 29 (406mb same, but different geometry) FDISK crashes. (I seem to remember this working for IDE drives back in the day.)
    With the BIOS set to HD "NO", the controller bios sees the HD and I can FDISK and FORMAT just fine. I went ahead and used the whole 406mb.
    Then I could do the install from the DOS-5.0 diskettes, just fine.
    On reboot it will not boot from the HD, I have "C then A" set in the bios.
    If I boot off the diskette I can then go to C: and everything is in order, system files, autoexec.bat, config.sys all look good.
    If I boot without the diskette in I get the old No system disk...Press any key to reboot... message.
    I used to do this for a living at one point, but other with something funky with the controller I can't think of what I missed.
    I am putting together another 386 for retro gaming, this system will eventually have 2x 360k and 2x 720 drives, with multiple emulators installed for creating/copying low density diskettes for various systems.
    Any help appreciated, thanks!
    33,138
    Did you set your boot partition active? That's often overlooked.
    Northern VA - USA
    202
    Should have included that in the description, yes, the HD has one partition, it is DOS/PRIMARY/ACTIVE. Thanks.
    Mar 2011
    Virginia
    2,300
    Try using GSETUP to set the hard drive type.
    It's at http://members.dodo.com.au/~slappane...e/software.htm
    If it doesn't list your exact type, use ANYDRIVE, it got my Compaq Portable III working perfectly.
    http://files.chatnfiles.com/Modem-Ma...s/00index.html
    ~Ian~
    Looking for a Gateway 2000 G6-333 - my first computer.
