Results 1 to 7 of 7
Thread: OS 9 and emulator and questions
    Default OS 9 and emulator and questions
    Hey All:
    As I am just now getting into COCO machines and focusing on Tandy/Radio Shack model computers for my retro computing platform, I have decided to try to find an emulator to make disks and so on.
    Can someone recommend a good emulator that works with Windows 7 and advise how you would hook a retro 5.25 drive to your modern machine... basically, What do I need to support my COCOs and Model 4?
    Also I put out to everyone that I am now focusing on Tandy so I am looking for a 1000tx and a 1000hx and a couple of CM-8 monitors.
    Appreciate all the help so far.
    Mike
    Seeking models for vintage collection always.
    Somewhere near Chicago
    645
    Sadly the best emulator I know of, works in msdos. Do you have any older machines you could use? I use an old thinkpad 760XD which is a p166, although a decent 486 should be fast enough for real time speed!
    http://www.vavasour.ca/jeff/trs80.html
    Scroll down " TRS-80 Colour Computer 3 Emulator (released to freeware) "
    Best thing about it, is its support for a utility that allows you to copy your virtual images to diskettes for use in real cocos!
    Currently seeking a Compaq Deskpro 386
    @twolazy: right now I don't actually have an old DOS machine lying around. I have been looking for a 486DX2-66 for use for my BBS software (MajorBBS) and two would better so I have my BBS box dedicated again. I am game if someone has one for a "good home" or the like. I will definitely take your advice on the emulator -- Thanks (again).
    @everyone: I am focused on Tandy/RS machines and so I am still seeking (with preference to local Kansas City area for shipping reasons) a Tandy 1000TX with hard card, and actually want to find a 1000HX as well... and the CM-8 monitor too The monitor is obviously the heavier part
    PM me if you can help on either front.
    Also look into Multi Emulator Super System (MESS). Among the billions () of other systems supported are the CoCos, Model 4 and the 1000 series machines.
    I don't have much advise regarding 5.25" floppies though. I would guess you'd probably have the most success with Win XP or lower. I've never tried connecting a 5.25" drive to any of my Vista or Win7 machines.
    Tandy machines are an interest of mine as well. Good luck on your quest for the CM-8. They don't seem to be that common, but they are a great match for the CoCo 3.
    __
    Trevor
    I also like MESS, it's easier to use and good enough to test most of the CoCo software.
    You can always install a 5.25" drive regarding the MS OS you have. If you want to create standard PC floppies (1.2M, 360K) there's no problem (although the latest Windows need to open a CMD windows to achieve it). If you want to mess with alien formats, CoCo for example, you'll need a WinMe or lower. Windows 98SE is still an excellent choice. Of course you can try with Linux...
    Also keep in mind that not all the combos disk controller+5.25" drive work fine. Most motherboards have mostly incompatible controllers that usually doesn't write correctly the disks.
    Check out this one. It was written for the Dragon, which is a CoCo compatible. I understand that with the Tandy ROMS it emulates the CoCo. And it does Windows!
    http://www.6809.org.uk/dragon/xroar.shtml
    Tez
    Sep 2006
    South Florida
    1,640
    I think most folks nowadays use VCC - get it at http://vcc.20x.cc/
    Supports the SSC, FD-502, IDE, and even HDBDOS in the IDE, and also has an HDD image for download, that boots straight into Nitros9 v3.2.8.
    Runs fine on my laptop - Dell Inspiron M501R (AMD Phenom II X4 x920 Black Edition/8GB RAM/500Gb HDD) with Windows 7 Pro 64-bit.
    Also tried it out on my new Dell XPS 15 (L502x, Intel i7-2720QM/8GB RAM/750GB/nVidia 525M) with Windows 7 Home Premium 64-bit, again, no issues.
    Hit up ftp.maltedmedia.com for software/manuals/etc
