Results 1 to 10 of 54
Thread: 26 Pin Hard Disk Connector
    Default 26 Pin Hard Disk Connector
    Hi, I recently acquired an Epson PX-16, with it came a base unit in which there is a floppy drive and space for a hard drive.
    The connector that looks as though it once had a disk drive connected to it is a 26 pin female IDC connector.
    In the manual it states that the unit supports a 'type 3' HDD.
    Does anyone know what sort of drive I would need for this, there's no separate power connector so I'm assuming power is also supplied by the 26 pin connector.
    Thanks, Charlie
    Quote Originally Posted by Thx1138 View Post
    Thanks, Charlie
    Almost certainly a proprietary plug for some special drive, however the drive mechanism could have been standard MFM/RLL or IDE. MFM/FLL and IDE have a lot of redundant grounds, so some manufacturers condensed those to fit smaller proprietary connectors. If you could find pinouts an adapter cable could probably be made. I made a custom 40pin to 50pin plus power adapter cable for a Macintosh Portable I was restoring, interface was standard SCSI, but apple chose to use custom plug. Though you could be completely out of luck and it could be a useless proprietary mechanism like the PS/2 Model 25&30, where the drives were unreliable and no longer available because of that.
    My Vintage computer/blog site
    31,212
    I'm going to go out on a limb here and say that it's likely a connector for a second 3.5" floppy. See, for example this list of EPSON drives.
    Could surely be, but there are mentions of HDD support for the PX-16, so there's got to be some kind of HDD interface in there, or some kind of slot/interface to add one.
    Dec 2005
    Toronto ON Canada
    7,136
    Does it have an external opening for a floppy drive?
    There were 26-pin floppies but there was also a 26-pin JVC HD interface used by various Japanese manufacturers; matter of fact I have one in one of my Toshibas.
    Here's some info:
    http://www.pd.com/gb15xx/messages/1489.html
    4,247
    Is it possible that the same connector is used for either a hard drive or a floppy that is mounted in the free bay? That seems to be the only way the PX-16 drive base could be field upgraded with the complex jumper settings defining the configuration.
    Thank you for all your replies, I'm pretty sure it's not a floppy connector purely because there's already a floppy drive in the unit and it uses a different connector. What I'll do is take a picture and put it up. I think MikeS might be on to something as this is a Japanese machine.
    Charlie
    Ok, here are some pics:-
    These show the connector I'm talking about which seems to come off of a daughter card. You can see the floppy connected to the board along with a spare floppy connector.
    Charlie
    Also, anyone recognise this layout of this mini din?
    Charlie
    The last mini-din I think is the Microsoft Bus. The hard drive or whatever IDE looking connector I'm not sure about but so many devices had a proprietary converter between the standard drive and their device it's probably going to be easier finding another unit or drive from a unit to know for sure what would go there.
