February 12th, 2010, 05:33 PM
#1
Troubleshooting
[wiki]Category:How_To[/wiki]
Basics
Before diving into the specifics, a few essential checks which will often diagnose or even fix the problem.
Visual inspection
This one doesn't even require any specific equipment, other than maybe a magnifying glass. Give the item a thorough visual examination and note anything out of the ordinary. Things to look for include:
- Scorched or burnt-out components
- Residue from leaking components
- Broken wires, connectors or [wiki]PCB[/wiki] tracks
It helps to clean dirty equipment up before inspection, although excessive scrubbing can of course itself lead to yet more problems!
Reseat cards, cables and ICs
Sometimes, simply [wiki]reseating[/wiki] components is enough to revive even a completely dead machine. It's easiest to start with larger components (expansion cards, cable connectors) first and, if this doesn't help, work down to smaller parts ([wiki="Integrated Circuit"]IC[/wiki]s, crystals, etc.).
Power supply
A faulty power supply can cause all manner of strange and often otherwise inexplicable symptoms. Use a [wiki]voltmeter[/wiki] to ensure all power rails are within the manufacturers tolerances (or if the tolerances are unknown, that the voltages are at least sane). If an [wiki]oscilloscope[/wiki] is available, this can be used to check for [wiki]ripple[/wiki] on DC power rails.
Common, model-specific problems
Similar machines often fail in similar ways. Use your favourite search engine to look for common problems with your specific hardware (and hopefully their solutions).
General Problems
- [wiki]Dead computer[/wiki] (blank screen, no response)
Display
- [wiki]Garbage screen[/wiki] (random characters/colours)
- [wiki]Distorted image[/wiki]
- [wiki]Snow (TV screen)[/wiki]
Keyboard
- [wiki]Sticking keys[/wiki]
- [wiki]Intermittent keys[/wiki]
- [wiki]Nonfunctional keys[/wiki]
Disk Drive
- [wiki]Cleaning heads[/wiki]
- You may not post replies
- You may not edit your posts
Forum Rules
