Page 6 of 6 FirstFirst ... 23456
Results 51 to 53 of 53
Thread: AT2XT keyboard converter
  1. #51
    May 2019
    San Diego CA
    15
    I am having an odd bug/issue with my AT2XT.
    I am using Sergey's Micro8088 and the AT2XT that is part of the design.
    Most everything seems to be working correctly except...
    Shift + arrow keys.
    If I use the numpad, shift+arrow keys work as expected in edit.com and other text editors to highlight text.
    If I use the inverted T arrow keys, shift+arrow key acts as if shift is not being held and the cursor moves with no highlighting.
    I am setup to convert my CF card to a virtual disk image and back, all of that works reliably. So using the exact same drive image & utilities, shift + inverted T arrows works as expected in VirtualBox, so I'm left pointing fingers at the AT2XT.
    Is this a known issue, is this something I missed in configuration?
    Thank you.
  2. #52
    May 2019
    San Diego CA
    15
    I found references to this problem online. The only suggestion was to upgrade from 0.94 to 0.1d. I've tried that with no change to the shift + inverted T arrow keys behavior.
    I may be expecting behavior that can't happen or otherwise misunderstand AT2XT, as I have a key scanning program which shows some odd behaviour of the shift key pressing itself when using the inverted T arrow keys, so I'm guessing the AT2XT is translating the arrow keys into num pad arrow presses depending if Numlock is on or not.
  3. Default
    Quote Originally Posted by modem7 View Post
    Member schnurzel came up with some alternative firmware for the converter's PIC chip. It maybe the answer. Available at [here].
    You will need a device that can program the firmware into the 12F629 PIC chip. Alternatively, some of the people/companies at [here] could supply a programmed 12F629 for you.
    The alternate firmware above worked great with my Tandy 1000 SL/E.
    Just wanted to let everyone to know - try that firmware if you have a Tandy 1000 SL/TL/RL/RLX system.
