Results 21 to 30 of 44
Thread: AT2XT keyboard converter
  1. #21
    I tested this AT to XT keyboard converter with Juko ST motherboard and a PS2 keyboard. Almost everything works well, including SHIFT, CAPS LOCK and CTRL keys. However, I have a minor problem. When playing Prince of Persia 1 on this XT using the converter, the SHIFT key is not recognized and I can't take small steps by pressing SHIFT+Arrow key. If I do that, the prince will still take a normal step as if SHIFT wasn't pressed. The SHIFT key works well in the same game (for example, when drinking a potion), in MS-DOS and also in other apps so I am not sure what the issue is.
    Does anyone have the same problem?
  2. #22
    You might get a more definitive answer by borrowing an XT keyboard.
  3. #23
    Nobody around here owns an XT keyboard. The only XT keyboard that I have here has many dead keys and can't really be used. eBay wants at least $100+ for an XT keyboard in unknown condition. I believe the SHIFT key issue is timing-related, e.g. Prince of Persia makes some assumption on timings to detect Shift-Arrow combinations, which work well with an original keyboard but not with the converter.
  4. #24
    Quote Originally Posted by mdanh2002 View Post
    I just looked and there were plenty of XT keyboards under $50. Some were as low as $10.99. These are working keyboards.
  5. #25
    Well, those don't show up when I search eBay here from Singapore. Maybe those do not ship to Singapore hence they don't show up.
    The only thing I find is this, for almost US$100 with shipping to Singapore:
    https://www.ebay.com.sg/itm/Vintage-...kAAOSwaeRZJNcH
    Can you post the eBay link?
  6. #26
    https://www.ebay.com/sch/i.html?_fro...board&_sacat=0
    Alternatively I have some XT keyboards -- but the shipping would be high.
  7. #27
    Stone - quit the badgering already.
  8. #28
    6,709
    In post #493 of the AT2XTKB development thread, member schnurzel posted some alternative code for the AT2XTKB.
    The link to that post is [here].
    In the later posts of #499 and #528, other members reported that the alternative code fixed some issues.
    Maybe you should try that code.
  9. #29
    Thanks for the link! Let me try with the updated code ...
  10. #30
    Jul 2010
    Silicon Forest, Oregon, USA
    726
    Quote Originally Posted by Erik View Post
    The links to the firmware above had been broken for a while. @Erik, can you please fix these links or remove them altogether (the firmware is in the XTATKEY_094.zip)?
