Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: AT2XT keyboard converter
  1. #31
    Quote Originally Posted by sergey View Post
    The links to the firmware above had been broken for a while. @Erik, can you please fix these links or remove them altogether (the firmware is in the XTATKEY_094.zip)?
    I believe it's due to improper configuration when the domain was changed from vintage-computer.com to vcfed.org. The correct link should be:
    http://www.vcfed.org/forum/attachmen...6&d=1300557151
  2. #32
    Is anyone making and selling these adapters?
  3. #33
    Jan 2011
    Middletown, Maryland USA
    148
    Not that I am aware of, but you can order them, yourself, based on the PCB designs that Scott and I have both posted to OSHPark, and then build one, using commonly-available parts. It's not at all a difficult process.
    - Alex
  4. #34
    32,716
    Or you can do what I did for the prototype--just use a hunk of perfboard. It's not a complicated circuit.
  5. #35
    Jul 2014
    New Hampshire, USA
    177
    Quote Originally Posted by allCAPPS View Post
    I have extra pcb's and can easily put one together for you. PM me and we can work out the logistics.
    - Gary
  6. #36
    what has happened to the links for source code?
  7. #37
    32,716
    When the vcf.org was created from vintage-computer.com, someone forgot to update attachment links. Fortunately, I happen to have the file here:
    You know, my attachments are really for public consumption. Is there any way I can simply expose the entire lot of them, without having them linked to messages?
    Attached Files Attached Files
  8. #38
    6,393
    A link to Chuck's later version, version 0.94 (XTATKEY_094.ZIP) is at [here].
    A slightly enhanced version of that is introduced at [here].
  9. #39
    Jul 2014
    New Hampshire, USA
    177
    I've had a few emails lately asking about PC boards and assembled units. I got a bit carried away and ordered/built up a batch of these with 3D printed cases etc. I still have some spares if anyone is looking for one.
    - Gary
  10. #40
    Hi,
    I found this keyboard: key tronics E03602 EL FR (french one).
    It seems XT compatible, but these are not switches on the second photo. Instead there are 3 holes. Do I need to solder switches myself? For XT compatibility I have to connect the 3 of them? It is not clear to me how to configure it.
