Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: 8bit Friendly ISA VGA cards
  1. #21
    Dec 2012
    Russia, Moscow
    130
    Today i booted system with CGA video card and non-working VGA Trident TVGA9000C card together. I was able to dump ROM bios from C000h segment to disk and copmpare it with original BIOS. Dump similar to original BIOS but contain 0xFF bytes at random locations. Every time when i make new dump 0xFF bytes changed locations. I am not discovered dependings. Random places, random 0xFF bytes. Of course, calculated checksum of dump never matches to checksum of original ROM. So, i think it's totaly hardware problem around TVGA8900D and TVGA9000C chips. Maybe, to remedy the situation the presence of buffer like 74LS245 on the data bus, i am not sure...
  2. #22
    Apr 2009
    scandinavia
    255
    hello
    dont know if this card is the most advanced 8bit card ? .. i dont know if it demands 386 or do run in 8088 PC's ??
    seems like a 8/16bit bios switch , but do data transfer also run in 8 bit ?
    http://www.ebay.com/itm/Number-Nine-...-/351704210182
    I am saving money, and going to outbid on this auction.
    /cimonvg
  3. Default
    I just tried an ATI MACH32 16 bit on my Tandy 1000 TX and it seems to work fine.
  4. #24
    Dec 2012
    São Paulo country, Brazil
    853
    I have a Trident with the TVGA9000i-3 chipset. It has an 8 bit/16 bit jumpers, but definitely it doesn't work neither in my 5160, nor in my XT clone, 8088 based.
    I tried D4.01E and D3.51 firmware, no changes. The computer seems to boot, but there's no output signal (monitor goes into stand-by mode).
  5. #25
    Hi guys .
    This vga card has cl gd5401 cirrus logic ic ,but does all with this ic work on any 8 bit isa xt machine?
    http://www.recycledgoods.com/media/c...-card-4.39.jpg
    And do i need drives on dos boot or is it plug n play?
    Best REgards
    JOSÉ
  6. #26
    6,884
    The very first post of this thread lists the chipset, so it might work.
    All ISA VGA cards do not require drivers to work for booting and normal DOS usage.
  7. #27
    Jan 2017
    Galicia, Spain
    194
    Another one for the list
    http://www.vgamuseum.info/index.php/...3-hmc-hm86314q
    Hualon Microelectronics HM86314Q
    it even has drivers for Windows 286/386 2.1!!!
  8. #28
    For all Olivetti M24 machines; even when jumpering both the P8 board and the mainboard to disable onboard, some cards that have compatibility like the VGA Wonder XL will simply freeze the machine with nothing to display.
    SpeedStar 24X with the "16-bit" BIOS access jumper disabled (set open) will make the machine boot, but no video is shown. I'm not even sure if that card is 8-bit compatible at all, actually.
    Join the penny pincher army today!
  9. #29
    Confirmed cards with no absolute compatibility for the Olivetti M24 in any way; SpeedStar 24X, Paradise VGA 16, ATI VGA Wonder XL, and the later ISA Dolch PitViper models. Even if the machine can POST and boot, you can indicate whether the video card is actually found if there is a beep after all the startup tests have succeeded.
  10. #30
    35,365
    I used a Tsenglabs ET4000-based VGA card on my AT&T 6300 for a time.
    I tend to go by chipset rather than brand. It's less confusing that way.
