Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Compaq Portable III
    Mar 2011
    Virginia
    2,300
    2
    Default Compaq Portable III
    The Compaq Portable III was the third model in Compaq's line of portable computers. The screen pivots for a comfortable viewing angle. The keyboard does attach to the screen when it is being transported. The only expansions available for it is an internal 1200 baud modem and an external expansion chasis (model 2662A) that holds two full length cards. Like other older Compaq computers, the internal BIOS settings can only be changed or configured via the use of a diagnostic disk.
    Here's the specs,
    1. Model: 2660
    2. Year introduced: 1987
    3. CPU: Intel 80286
    4. RAM: 640k base memory. Expandable up to 2048kb.
    5. Storage: 20mb or 40mb Conner hard drive. 1.2mb 5.25 floppy drive.
    6. Ports: RGB, Parallel, Serial.
    7. Display: 10" red gas plasma screen.
    8. OS: Compaq DOS 3.31.
    9. Original Price: $4,999.00 with 20mb hard drive.
    $5,799.00 with 40mb hard drive.
    Dec 2005
    Toronto ON Canada
    7,103
    Default "No internal BIOS"???
    "No internal BIOS"??? Really???
    Mar 2011
    Virginia
    2,300
    2
    Really! There's no BIOS or setup screen. You have to use the diagnostic disk to enter in the settings.
    ~Ian~
    Looking for a Gateway 2000 G6-333 - my first computer.
    Dec 2005
    Toronto ON Canada
    7,103
    Quote Originally Posted by DOS lives on!! View Post
    What you mean is that you need a setup program on disk to set the BIOS options. Every PC & compatible has a BIOS AFAIK; without a BIOS, how would the computer be able to read the setup disk in the first place?
    Mar 2009
    Pleasant Hill, CA USA
    2,720
    There ya go fixed.
    Mar 2011
    Virginia
    2,300
    2
    Yeah, that's what I meant to say. I was trying to say, "There's no way to configure the internal BIOS without the use of a seperate configuration program, such as it's own Diagnostic Disk." Or, there is the option of using GSETUP.
    ~Ian~
    Does anyone have this disk or the other disks for this machine? I have one for sale and would like to provide copies. Thanks
  9. #9
    Oct 2017
    SE Michigan, USA
    496
    Found a site that has the diagnostic diskette listed: https://forum.winworldpc.com/discuss...stics-diskette
    Note: these might be images of the diskette, hard to tell.
    360KB 5.25" Floppy: ftp://ftp.hp.com/pub/softpaq/sp0000-0500/sp0316.zip
    720KB 3.5" Floppy: ftp://ftp.hp.com/pub/softpaq/sp0000-0500/sp0308.zip
    GSETUP would also suffice: http://www.minuszerodegrees.net/5170...170_gsetup.htm
    Current retro systems:
    2x Commodore 64 Breadbin 250407 Rev. B and C
    Packard Bell Pack-Mate 28 Plus, aka, the Ultimate Sound Card machine
    iMac G3/600 Graphite, Mac OS X 10.4.11 Tiger, Lubuntu 16.04.3 LTS
    iMac G4/800 Lampshade, Mac OS X 10.4.11 Tiger
    YouTube channel: https://www.youtube.com/c/RetroPCUser
  10. #10
    Thank you so much. You are the best!
