Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 91 to 100 of 130
Thread: PET ROM/RAM replacement board
  1. #91
    Outer Mongolia
    1,567
    Quote Originally Posted by gubbish View Post
    Well, to make things more confusing, I just tried a second PETvet that I had built on my second 8032, and I see no trace of the behavior I was observing before. Quite the quandry.
    Silly question, I know, but if you swap the boards does the problem follow the PET or the PEvet? ;^)
    I've complained myself about the problem I've been having with two out of three of my Dynamic PET boards, in which I get the occasional video glitch involving misplaced or incorrect characters. I'm convinced on those machines the problem lies with the address multiplexor circuit in front of VRAM glitching, but I haven't been able to chase it down. I wonder if on the 8032 that's exhibiting the issue the delay introduced by the "mapper ram" could be causing a similar glitch? I get the feeling that the timing constraints in that circuity are really tight, and perhaps if the machine in question just happens to have a marginal cap or something somewhere on the board introducing the PETvet is just enough to push it over the edge?
    Does changing the mapping settings on the PETvet affect things at all? (IE, lets's say you set the board up so the mapper just passes through everything, the RAM on the PETvet isn't used at all, does the problem persist?)
  2. #92
    Apr 2011
    San Francisco, CA
    500
    Thanks very much for the tips.
    Did a bit more testing, and found out that the problem may lie with the individual PETvet I was using to test.
    PETvet #2 so far has tested fine on *both* PET 8032s, while PETvet #1 showed the issue on 8032 #1. I am just about to test it on 8032 #2. What happens here will provide some useful information.
    I'm going to check all the PETvet boards I've built so far to see if there's a discernable pattern. If only the one PETvet shows the problem, that's a good thing
    The only difference with that board is that I used larger capacitors with the MAX232 serial driver, 10uF instead of 0.1 uF for the PETvet #1. The nominal value is 1uF for the MAX232 chip, but up to this point I haven't had any issues. Don't know if this is related to the problem or not.
    I will test the various boards and see what happens.. Thanks again
    - Mike
  3. #93
    Apr 2011
    San Francisco, CA
    500
    The problem indeed follows the PETvet and not the PET
    PETvet #1 has issues on both 8032s, while PETvet #2 tested fine on both.
    The issues did not appear exactly the same - on PET #1 the basic prompt came up fine and then the cursor started jumping to the right after pressing return a few times.
    On PET #2 shows "commodore basic 4.0", then a line shifted to the right that says "11486.253 bytes free" (not the exact numbers, but something like that) and then a more shifted "ready" under that.
    Which may mean that just this one board has an issue. I'm setting it aside for now and testing the others.
  4. #94
    Apr 2011
    San Francisco, CA
    500
    The problem appears to be confined to that one PETvet board, so I'm sure I made a hamfisted construction error somewhere.
    The other PETvets, and a new one I just built are all testing properly on both the 2001 and the 8032, so I'm ready to send these out to the brave early testers. 2 have been sent out so far, with more to come. If you've sent me a message about a PETvet, I'll contact you about it in short order. I hope this gadget helps people to get their PETs (and possibly other 6502 computers) up and running.
    The PETvet would also make a good start for a simple 6502 homebrew computer design. It takes care of the RAM, ROM, and addressing issues, and pretty much all you would need for a full computer is a clock source and a reset signal. There may be other details I'm forgetting but these are the biggies.
  5. #95
    Apr 2011
    San Francisco, CA
    500
    I have a couple of additional PETvets ready, and I'll get these out to the next brave testers soon.
    I made another discovery which I don't quite understand, so perhaps some of you will know more than I.
    I found out that a PETvet that I had previously tested to work on both a 2001 and an 8032 mysteriously stopped working on a 2001.
    After some nervous headscratching I realized that I had swapped the 6502 which used to be in the PETvet with the processor which was originally in one of the 8032s - While my other 6502s had the MOS logo, with "MPS 6502", this had an "S" type logo and had a model number "SY6502A".
    All of the MOS 6502s that I tested worked fine in the PETvet, but the SY6502A did not, and it was not completely consistent. Perhaps one out of 10 times I tried it, the beginning of a "Commodore BASIC" message was on the screen with some additional garbage characters.
    I imagine there's a subtlety of timing that is causing the difference.
    Just wanted to see if anyone had any insights into this. But so far every MOS 6502 has worked in the PETvet without issue.
  6. #96
    Outer Mongolia
    1,567
    No insights, but I can try to replicate your results when I finally get hacking on my PETvet. I'm pretty sure my "spare" 6502 is a Synertek label one. (Actually, come to think about it I think it's that "spare" that's actually installed in my 2001-N/4032.)
    When you say "2001" do you mean a static RAM 2001, or a Dynamic RAM (2001-N) board?
  7. #97
    Apr 2011
    San Francisco, CA
    500
    It's a big-keyboard 2001-N.
  8. #98
    Jan 2012
    Surrey,BC,Canada
    147
    Hello,
    Today, I received the PETVet from Mike.... This is my first experience with this wonderful device. Like Tezza said, the analogy of pacemaker to a human heart, the PETVet is for the PET.
    From my experience on my PET2001-8 repair, having built Scouter3D PETROM/RAM replacements, I should have been content with the setup.
    However, the PETVet as is gives my PET2001-8 additional (new) specs:
    1. New set of ROMS ---BASIC 2 ROM
    2. Additional memory -- 32K of RAM
    3. Flashable ROMS
    4. Additional features...see documentation at bitfixer.com
    ....http://s6.postimage.org/r11i8039d/BASIC2_32_K.jpg
    ...notice that I still have that screen anomaly (location 513 character on the screen).
    Well, I emptied out again all ROM/RAM sockets, took the MOS6502 cpu and plugged it into the PETVet board.
    The PETVet comes with 3 switch settings. SW setting #1 is for my PET2001. Mike has already set it up for me. I referred to the first PETVet documentation just to confirm things are set properly.
    -http://s6.postimage.org/db6yz7g5d/PETVet_Close_Up.jpg
    The PETVet has a 'socket-header-socket' combination which would allow it to be plugged in to the 6502CPU socket on the motherboard. It sits perfectly, right height and right placements.
    Here are some of the first pics I made...
    http://s6.postimage.org/7fd1bt0u9/PETVet_Pics2.jpg
    http://s6.postimage.org/wrrolqb9d/PETVet_Close_Up1.jpg
    http://s6.postimage.org/4ntrl72bl/PETVet_Side.jpg
    http://s6.postimage.org/gymq59och/PETVet_Pics1.jpg
    I loaded the first CURSOR#16 cover from tape, ran it for a while and left the PET as if it is on a 'burning test'.
    Everything runs cool (ATMEGA, RAM, ROM and support chips) or 'just warm'. However, the MOS6502 chip has a hot spot on the middle. I might take a small heatsink in glue it on top of the 6502 chip --give it a longer life.
    Here it is in action!!
    http://s6.postimage.org/pfm8g6t1d/PETVet_In_Action.jpg
    New Life indeed to an Old friend! PET2001-32
    Rizal
  9. #99
    Apr 2011
    San Francisco, CA
    500
    Great to hear that the PETvet is working for you!
    As soon as I get some time I'll be posting the full source code and detailed instructions about how to flash the firmware and reprogram the ROM images. Also two additional brave testers will be getting their PETvets shortly.
    With the input from the first few PETvetters I can hopefully fix up any issues before making another batch of PCBs.
    Anyway, great that this could bring some new life to an old buddy.
  10. #100
    Great pictures Riza, thanks for posting.
    Mike (gubbish), what happens with those boards where the RAM is soldered in. Does the PETVet bypass that RAM somehow?
    Tez
