Results 1 to 10 of 13
Thread: Harvesting soldered parts from non-functional boards...
    Default Harvesting soldered parts from non-functional boards...
    Looks like an appropriate posting location...
    I've been harvesting parts from non-functional clone motherboards, and wonder about some of the nuances others may use:
    Typically I localize the heatgun on the solder side, then rap the board down over a cardboard box. Excess solder splashes in thin coatings over the surface of the components, although it can usually be etched or wiped away. I might try over a bucket of water, in the hope that the solder drops would be separated from the components, hardening before it "splashed" on them.
    Thoughts?...
    I've always used a desoldering iron which goes over each pin to melt the solder then generally I pull the component off myself. A heat gun sounds like a much easier way to do it other than the symptom you're referring to. I would stick to pulling the component off vs banging it on something just to prevent that splashing. That or possibly put the board on it's side so it drips down vs onto the package, etc. I know some folks heat it up from the component side or use that soldering flux stuff. With the heat I'm not sure how likely it is to damage the parts.
    Apr 2011
    San Francisco, CA
    494
    I also use a desoldering tool that goes over the pins as, and find that it works pretty well. Some pins are troublesome, and for those the trick is to add a little bit of new solder to the joint. Somehow after you do that the desoldering tool sucks it right up. It's important to keep the tip of the desoldering tool clean so the suction happens quickly when you release the bulb. Also make sure you squirt out the removed solder somewhere before putting the tool back over the board, since you can spray solder everywhere if you forget.
    30,632
    Before I used the heat-gun approach, I used a propane torch (outdoors)--stank to high heaven. Either one is only useful for harvesting gross parts--small SMT stuff generally requires a more refined approach. If it's a fine-pitch SMT item, I'll use a hot air pencil.
    I don't worry about the solder blobs; usually they can be knocked off with the end of an X-acto knife.
    I've also heated up the solder-side, then rap it on that side to get a little more of the excess solder. Really, for those that haven't tried it (I've also done the propane torch), the speed which you can work through boards is pretty good (my heatgun is a nice Milwaukee unit). As long as you are careful the heat won't damage components.
    I'll try into a bucket of water and see what it does (although the sudden heat change might be bad for the chips I am trying to harvest)...
    30,632
    Quote Originally Posted by IBMMuseum View Post
    I'd be afraid of that also.
    I've also known people to strip boards by putting them in an electric skillet filled with peanut oil. Heat to about 380F/190C. Since 63/37 Sn/Pb solder melts at 188C/370F, the oil bath will liquefy all solder without burning the components. Wear eye and skin protection--hot oil is nasty, although the oil temps used for deep-frying are generally higher.
    For delicate SMT ICs, I use Wood's Metal powder to lower the melting point down to about 170F, where it can be melted by an ordinary PAR38 spot. Clean-up is easy and it preserves the PCB traces. WM contains cadmium, so don't breathe the fumes. Dispose of responsibly.
    Mar 2010
    Florida, USA
    1,958
    I've seen where people use clothes irons to melt the solder and lift the components off... I'd be rather scared to do that. Right now, there's not alot that I need for the parts bin, so I tend to just hold onto the populated board(s) and desolder components individually as needed.
    That heat gun method looks nice though - I've seen vids of guys harvesting parts with those before... MAN!
    Currently seeking:
    Jul 2009
    Central Florida
    3,732
    I guess I am old school. Iron & solder sucker for me.
    *FrankG*
    Apr 2010
    Albany, OR USA
    869
    Have you considered using a non toxic alternative to Woods Metal? I believe Fields metal has a simalar melting point and does not produce toxic gasses
    Hamilton, Ontario, Canada
    3,754
    I use the paint scraping type of hot air gun approach too, but, I use a couple of saw horses with a box that is about 3 ft x 1 foot so I can do several boards at the same time going back and forth across all the boards. A regular tap with the heat gun in the area I'm working on dislodges the chips and they drop into the box.
    This setup allows the solder, which has to fall further, to harden before it hits components in the box.
    I routered a channel in the 2 x 4s at the top of the saw horses to set the board upright and use that part of the setup to harvest the SMT parts in the same manner, but with the boards being held vertically.
    Just keep the gun moving at a constant speed and you won't damage the chips.
    Legacy Computers and Parts
