Results 1 to 10 of 16
Thread: Aix ps/2-/386
    New Zealand
    3,895
    4
    Default Aix ps/2
    Whilst reading through my OS/2 manual about about OS/2s boot loader I came across AIX which could be installed on 386 class machines. From what i can gather it was a joint project between Lotus and IBM called PS/2 AIX around 1987.
    Did anyone on these forums use it at all in a production enviroment? Seems quite interesting http://www.ibmmuseum.com/ohlandl/AIX...X_For_PS2.html
    I'm also curious as to the specs of the computers you actually ran the OS on, particuarly non IBM branded stuff.
    Full installation is something 90 1.44meg floppies and scsi hdd I gather- http://ps-2.kev009.com:8081/moreaixps2/aix-supp-hw.html
    List of recommended, read IBM, machines- http://ps-2.kev009.com:8081/moreaixps2/aix-supp-hw.html
    Quote Originally Posted by Caluser2000 View Post
    There are those that run (and occasionally develop for) AIX on PS/2s (last available version 1.3) or later releases on RS/6000 at the comp.sys.ibm.ps2.hardware newsgroup (there even may be more specific groups active too)...
    Quote Originally Posted by IBMMuseum View Post
    Just out of curioisty, what sort of companies still use PS/2s?
    I never actually seen PS/2s in a production environment before.
    Quote Originally Posted by EverythingIBM View Post
    A few years ago I was contacted by a power company, whom wanted to replace a floppy drive in a PS/2 Model 50. I tried to get them to update to something like a Model 77 (at least a little newer, it was a microchannel adapter for some special function that kept the unit in production). They just wanted the floppy drive (the system is going to quit in a worse way sometime).
    LOL, if they start to panic when the floppy drive fails, I don't want to know what they'll do when a capacitor on the mobo or PSU dies.
    Of course it's fixable, but companies don't have the time, or care really. Entities have an issue when thinking singularly to problem-solve.
    But I could be mistaken on easibility, PS/2s did harbor a lot of those bizarre miniature surface mount caps in sundry places. Must be the smallest *electrolytic* surface mount caps I've ever seen...
    Jun 2008
    Hamburg, Germany
    183
    In germany tenthousands PS/2 were used in banks, insurance and administration.
    LOL, if they start to panic when the floppy drive fails, I don't want to know what they'll do when a capacitor on the mobo or PSU dies...
    My thinking with the [Bermuda planar-based] PS/2 Model 77 (besides being a 486 and newer) is that the hard drive would at least be SCSI. Those 20Mb MFM (Model 50) or DBA EDSI (50Z) hard drives got to be close to easily dying. The 2.88Mb floppy drives (like on the 77) don't have anywhere near the long-term failure rate of the 1.44Mb PS/2 drives as well.
    But don't all PS/2s use proprietary connectors for the HDDs, regardless if they're IDE/SCSI?
    Which I think is convenient because then you only need one connector for power & data!
    --> Molex connectors can be stiff cheeseballs like 16-bit ISA cards wedged in awkward IBM NLX riser cards.
    Well then it's simple!
    You get an MCA IDE controller card from Recycled Goods for $500 and then make a molex to draw power from the proprietary PS/2 HDD cable.
    (Joke about Recycled Goods, I'm not sure if they carry MCA IDE controller cards. They do have overpriced model 50s and floppy drives). They could "recycle" a lot more if the prices were reasonable.
    As for the floppy drives... I took mine apart (well it's back together again and fine); it's really just standard parts that you can replace if you have the tools and patience.
    Many early PS/2s used proprietary hard drive connections, but all of the later models were standardized (SCSI, and to a lesser extent, IDE)...
    Feb 2012
    Hampshire, England
    160
    The PS/2 towers at announcement (Model 60 and Model 80) had EIDE drives with standard connectors.
