Results 1 to 10 of 10
Thread: Trying to revive Mac Color Classic
    Apr 2011
    San Francisco, CA
    511
    Default Trying to revive Mac Color Classic
    Hi,
    Just rescued a Mac color classic before it hit the recyclers. It currently appears to be non-responsive.
    When turning it on, you can hear a faint "zip" sound, and there is no response when pressing the power key of a connected ADB keyboard.
    I do have another working color classic so that might be useful for testing.
    Any ideas about first steps on this one?
    Thanks..
    Not leaky caps? They are certainly an issue with the Classic II?
    Tez
    Apr 2011
    San Francisco, CA
    511
    Thanks Tez,
    Checked the caps, and they were indeed leaky. Cleaned it off but still no luck.
    However, I remembered that a Mac LC won't start up when it has a dead PRAM battery, and I had read somewhere that the same thing happens with a color classic. I removed the PRAM battery to test, and it would still not start without the dead battery. But luckily I had a good 3.6V battery from a Mac LC, and swapped that in.
    Bingo, it worked! It lives again..
    This mac was in an elementary school, and has some sort of software called "At Ease" installed. On bootup it asks you if you are a student or a teacher. Don't know the teacher password so I was stuck being a student again. Now to dig out some OS install disks..
    Oct 2009
    Huntsville, AL
    1,256
    Can you just start with extensions disabled I wonder and have it boot normally?
    Quote Originally Posted by gubbish View Post
    Assuming it acts like a Classic II, booting the Mac with the "command/option/shift/delete" keys held down should force a boot from a floppy disk. You can then use something like SC HD Setup from a floppy to re-initialise the hard disk and reinstall an OS over the top of it.
    I had fun battling to erase with AT EASE especially where said hard drive wasn't an Apple one. I've written about it here.
    Tez
    Apr 2011
    San Francisco, CA
    511
    Another excellent write-up, Tez, this should definitely help in re-braining this Mac.
    Another step it looks like I need to take is patching the 7.1 startup disks with the right System enabler.
    I'm not so experienced with macs so had to search around a bit to understand why when I tried to boot from the 7.1 "install me first", it said that "this model" of mac was not supported. From what I have read you need enabler 401 in the system folder of both the "install me first" and "disk tools" disks for those to boot on a color classic.
    Will keep you posted..
    only the LC 475
    LC, LCII, LCIII do not need a pram battery to start up
    Apr 2011
    San Francisco, CA
    511
    Ah, ok. That is indeed the one I have that does not boot without a PRAM battery.
    Without many issues, I've installed 7.1 on the color classic. It didn't seem to complain about the drive, just formatted without issue.
    Now I'm gathering up the drivers and such to get ethernet working. Anyone know of some internet tools such as ping, telnet, etc that will work on System 7.1?
    Good to hear you've got it up and running!
    Tez
    Good ol' NCSA Telnet for telnet and MacTCP Ping for ping.
    Here's a good website for other classic networking apps: http://www.macorchard.com/classic/
