Results 1 to 10 of 12
Thread: Atari ST ACSI Cable
    Dec 2008
    libtard capital, California
    1,102
    Default Atari ST ACSI Cable
    I this DB19 cable straight through?
    34,621
    According my notes, it is. Basically a SCSI interface with some inverted signals.
    Do you have a multimeter? A continuity check would be straight forward if you're just pin matching.
    Dec 2008
    1,102
    thanks for the replies. I do not have the cable, and paying $30 for such a cable seem excessive, so I wanted to find out if it's something I can wire myself.
    Mar 2004
    Manitoba North of 50 degrees Latitude
    1,284
    Quote Originally Posted by dorkbert View Post
    Out of curiosity where did you find the cable at that price. They generally go for much more and I believe there are driver programs still available such as HDDriver.
    Economics isn't a real science. It's an evil art designed for the rich.
    Mar 2010
    Florida, USA
    1,964
    Why would a simple ASCI cable go for much more that $30? I ask that seriously - does it have the Atari logo or something?
    I would assume that even a custom cable place like Redmond Cable would charge ~$30 to wire one up. As Chuck said, it's essentially a straight-through cable.
    I'd be more curious about whether he's actually got a working ASCI drive for the ST IIRC, those were all MFM/RLL drives, and most are long since dead. I use the ICD AdSCSI adapter on mine.
    Currently seeking:
    Dec 2008
    1,102
    I think some of the megafiles goes from ACSI to SCSI to MFM/RLL (ACB4000A/4070) and later units goes from ACSI to SCSI, depending on the vintage. The cable was listed on fleaBay from an UK seller (15 pounds + 5 pounds shipping; comes out 30+ USD.) I think I'll swing by Halted and see if they have any DB19M in stock...
    Feb 2011
    2,425
    10
    They are expensive because 19-way d-types that are needed to make one of these are not available new any where I know of.
    G4UGM
    34,621
    When I built my ACSI cables, it was JDR that had the connectors and backshells. But no longer, I suspect, after more than 20 years.
    However, they're still around--B&A seems to have them. Be sure to get the matching backshell.
    Feb 2011
    2,425
    10
    Thanks for that. Very usefull.
    G4UGM
