Results 1 to 10 of 17
Thread: Fast 8-bit VGA?
    Apr 2007
    Western United States
    611
    Default Fast 8-bit VGA?
    Does anyone have any benchmark stats or anecdotal information regarding the performance of 8/16-bit VGA cards in 8-bit slots? I've tested a number of such cards in an accelerated Tandy 1000 TL/2, and am hitting a bottleneck that seems to be no respecter of chipset. Cirrus Logic, Paradise, Trident, and Tseng-based cards have been tried, and all display the same number of frames per second, per the "3DBench" utility. Perhaps 8-bit VGA is simply slow, and that's all there is to it? Might it be worth trying additional chipsets (ATI)?
    I will note that the Tseng and Cirrus Logic cards (the latter of which I am currently using) are the only ones of those tested that don't produce colored "snow" artifacts during fast palette-cycling effects.
    34,970
    8 bit ISA is slow--adding the higher memory requirement of VGA (more lines, more colors, more pixels) is probably the big limitation.
    Apr 2007
    611
    Thanks, Chuck. I figured as much.
    When it comes to video speed you can go crazy i saw a 16 bit isa vga card that was new but very cheap and was selling like hotcakes but the frame speed was slower than a old ega card on the other hand i tried a vga card with a tseng 4000 chip in a 486 board with the bus speed set at 8 mz giving 2200 fps at 10 mz bus speed 2800fps at 12.5 mz bus speed 3400fps that board went to 16mz but the scsi cont could not take it
    Sep 2003
    Ohio/USA
    8,082
    8 bit ISA video cards (256K RAM) are preety slow for any gaming, you might as well just deal with CGA or EGA on an XT.
    http://www.pcguide.com/ref/mbsys/bus...ndwidth-c.html
    The whole 8 bit bus can move 7.9mb/sec (at 8mhz) in theory BEFORE wait states come into play reducing speed like a rock.
    Somewhere near Chicago
    645
    Fastest card I have used on my 5150 is my Wyse ET4000AX 1mb. Its loads faster then my 2 trident cards. I only have a few video cards that can do 8 bit sadly. ATM I have the 5162's IBM CGA card in my 5150, the wyse is in my 5162. Its not exactly a common card though. It was mainly used for CAD and desktop publishing, but its a gaming monster!
    Currently seeking a Compaq Deskpro 386
    Quote Originally Posted by RBARDY View Post
    The question is: 2200 fps of what ? Surely not full frame updates (assuming the frame is a mode 13h bitmap @ 64KB the bus would need 137,5MB/s). Probably just some benchmark measuring x frames per second of whatever that benchmark is doing. Perhaps you are referring to the same "3dbench" benchmark as the OP ?
    Apr 2007
    611
    Quote Originally Posted by michal View Post
    The question is: 2200 fps of what ? ... Perhaps you are referring to the same "3dbench" benchmark as the OP ?
    Probably not. 3DBench reports 6.6 FPS with my Tandy setup. A score of 2200+ FPS with this utility would be nonsensical.
    34,970
    As long as we're not talking about using some fancy on-board acceleration, isn't the bog-plain Hercules mono card just about as fast as you can get? Yes, you can buffer screen frames with a VGA, but that doesn't help you with overall bandwidth.
    Apr 2007
    611
    For whatever it's worth, by utilizing the DRAM-refresh-adjusting "SPEED.COM" utility, 3DBench now reports 7.4 FPS in the VGA-hosting Tandy, up from the 6.6 FPS mentioned earlier.
    Now we're playing with power!
    In all seriousness, it does make a difference.
